spotted some many skylines in the past two weeks to many to mention lets see
rach at the st claires
IB6UB9 at the car wash consitantly
White R32 on wednesday night on the way to tuggers formal
also with the gtr p148rt i think thats it
bugger know I've seen so many more just can't think right now
p.s: Spotted Nismo nealy every day crazy bastard
Its a good time of year for a wash and i was it for free there :P
spotted ib6ub9 fyshwick. wave's exchanged. :)
d
And Clearly i spotted you too
https://www.sau.com.au/forums/topic/30059-spotted/page/251/#findComment-1780914
spotted a ferrari or lambo or SOMETHING LIKE THAT (have spend ages on google trying to find out what it was but have no idea) on Northbourne about 6.30pm
all i know is that it was red, it had kinda 'sharp' lines (not rounded), it had twin exhausts coming out of each side, a big rear wing, and a badge on each side of the back and the one on the left was kinda running writing and 2 lines.
and it was bloody loud (even just idling).
That thing is parked at a house round the corner from me. I think it is an old lambo. Very nice car though - and yes, very loud! If its there tonight I'll try to get a pic and figure out what it is.
https://www.sau.com.au/forums/topic/30059-spotted/page/251/#findComment-1782553
Spotted a silver R33 2 tone but had a wrx bonnet scoop along the parkway last night
that thing is always at chisholm shops...blue/grey two tone wit ugly rims n kit and a rexy scopp :D
spotted long on isabella drive today around 10:30ish...dude thoise rims look like chromies now...nice n shiney (you got them cleaned yeah?)
https://www.sau.com.au/forums/topic/30059-spotted/page/251/#findComment-1782835
No GTR, just the black GTS-t. You saw me on the way to the Tuggers formal at Rydges last week, i also spotted you in your street the same day on the way back.
https://www.sau.com.au/forums/topic/30059-spotted/page/251/#findComment-1783849
shell, i think i know the one you're talking about, old red car, (too) loud.
gets parked in braddon quite often during the week, was told that it had some sort of ferrari kit or something of the like, think the base is some sort of muscle car, ford maybe?
oh...that's interesting...i was pretty sure it was the real thing!! might be different car??
toonz, that'd be great if you get a pic- just so i can see if it's the same one and work out what it was cos it's realy annoying me now :)
https://www.sau.com.au/forums/topic/30059-spotted/page/251/#findComment-1785092
Yeah spotted myself getting a phone call at 6:00pm to do the Radford formal (yes I cancelled all my formal runs and took the car off the road) So without ruining the kids night I quickly slapped the car together and headed out. Yes I was missing a shirt… That wasn’t some sort of fashion statement or anything like that, I was just seriously in that big of a rush that I didn’t have time to grab one from inside after I finished getting the car ready.
Spotted the SAU convoy, looked good.
https://www.sau.com.au/forums/topic/30059-spotted/page/251/#findComment-1785146
Why yes… Yes they are.
The whole kit is from the Impul r34.
+ wide body
It isn’t finished yet! I have a carbon fibre bonnet and a flat drift boot coming. Jap spec rims should be in the guards soon 2.
Anyway thanks for the nice words dude.
Either way, all the skylines looked very tight, specially yours steve and another wine red r33 with a drift style wing. Are your front gaurds custom steve? the whole kit looked real nice, and different too?
Dayne
https://www.sau.com.au/forums/topic/30059-spotted/page/251/#findComment-1786003
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
