Spotted today:
Wine red R32 with a jracing sticker on the window, a black 32 with no wing and a black S1 33 in the canberra center carpark, a grey 4 door 32 passing the BP in civic, followed a black S2 33 down belconnen way (had QLD plates and a gtr wing) and HCR-32 at autobarn in belco minus it's rear bar while shopping for oil and option dvds.
https://www.sau.com.au/forums/topic/30059-spotted/page/290/#findComment-2058458
Spotted a white 32 Gtr on the Monaro hwy this morning around 7:45, had very stiff suspension, wide white Volk TE37's and a C-West type wing on it... looked very cool but the Asian looking guy driving it wouldnt look at me, so I couldnt give the usual nod of approval
https://www.sau.com.au/forums/topic/30059-spotted/page/290/#findComment-2060629
spotted a very hot bright red r34 near uni a little while ago. very nice sounding exhaust too. if you're reading this though mate, that area has lots of pedestrians, and giving it stick around there is looking for trouble. slow down, your car still looks and sounds fantastic. :)
https://www.sau.com.au/forums/topic/30059-spotted/page/290/#findComment-2061513
Sorry man, didn't even spot you til I drove past. Mate in the car told me off too, said you waved, but by then it was too late.
nah its all good I am only joking, it can be really hard to see through that tint, and it was raining.
https://www.sau.com.au/forums/topic/30059-spotted/page/290/#findComment-2061716
spotted a black R32 GTR going along state circle about 5.45 ish this arvo.
then at 6ish, a silver R33 gts-t going around parliment house. had wheels and an exhaust, was stock otherwise. looked very neat......
The R33 was me, on the way home from work. Where were you? It's funny, ever since I got hooked onto these forums I'm noticing every skyline I come across, than stare at the driver and wave. I'm not weird.........just sharing the love.
https://www.sau.com.au/forums/topic/30059-spotted/page/290/#findComment-2063001
i was on the forecourt of parliment house. im a cameraman and was doing a 'piece to camera' with a journalist when i saw you cruise by..... do you work at the house or just in the area? i've only ever seen 2 'lines other than mine in the carparks there.
https://www.sau.com.au/forums/topic/30059-spotted/page/290/#findComment-2063252
Are you talking around in the ministerial entrance area luke ??? if so i was out there at about 2ish one good thing is my pass lets me park right out front of the doors woot :rolleyes: those polls that retract into the ground are scary things lol
https://www.sau.com.au/forums/topic/30059-spotted/page/290/#findComment-2063309
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
