Spotted today:
Wine red R32 with a jracing sticker on the window, a black 32 with no wing and a black S1 33 in the canberra center carpark, a grey 4 door 32 passing the BP in civic, followed a black S2 33 down belconnen way (had QLD plates and a gtr wing) and HCR-32 at autobarn in belco minus it's rear bar while shopping for oil and option dvds.
https://www.sau.com.au/forums/topic/30059-spotted/page/290/#findComment-2058458
Spotted a white 32 Gtr on the Monaro hwy this morning around 7:45, had very stiff suspension, wide white Volk TE37's and a C-West type wing on it... looked very cool but the Asian looking guy driving it wouldnt look at me, so I couldnt give the usual nod of approval
https://www.sau.com.au/forums/topic/30059-spotted/page/290/#findComment-2060629
spotted a very hot bright red r34 near uni a little while ago. very nice sounding exhaust too. if you're reading this though mate, that area has lots of pedestrians, and giving it stick around there is looking for trouble. slow down, your car still looks and sounds fantastic. :)
https://www.sau.com.au/forums/topic/30059-spotted/page/290/#findComment-2061513
Sorry man, didn't even spot you til I drove past. Mate in the car told me off too, said you waved, but by then it was too late.
nah its all good I am only joking, it can be really hard to see through that tint, and it was raining.
https://www.sau.com.au/forums/topic/30059-spotted/page/290/#findComment-2061716
spotted a black R32 GTR going along state circle about 5.45 ish this arvo.
then at 6ish, a silver R33 gts-t going around parliment house. had wheels and an exhaust, was stock otherwise. looked very neat......
The R33 was me, on the way home from work. Where were you? It's funny, ever since I got hooked onto these forums I'm noticing every skyline I come across, than stare at the driver and wave. I'm not weird.........just sharing the love.
https://www.sau.com.au/forums/topic/30059-spotted/page/290/#findComment-2063001
i was on the forecourt of parliment house. im a cameraman and was doing a 'piece to camera' with a journalist when i saw you cruise by..... do you work at the house or just in the area? i've only ever seen 2 'lines other than mine in the carparks there.
https://www.sau.com.au/forums/topic/30059-spotted/page/290/#findComment-2063252
Are you talking around in the ministerial entrance area luke ??? if so i was out there at about 2ish one good thing is my pass lets me park right out front of the doors woot :rolleyes: those polls that retract into the ground are scary things lol
https://www.sau.com.au/forums/topic/30059-spotted/page/290/#findComment-2063309
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
