Spotted today:
Wine red R32 with a jracing sticker on the window, a black 32 with no wing and a black S1 33 in the canberra center carpark, a grey 4 door 32 passing the BP in civic, followed a black S2 33 down belconnen way (had QLD plates and a gtr wing) and HCR-32 at autobarn in belco minus it's rear bar while shopping for oil and option dvds.
https://www.sau.com.au/forums/topic/30059-spotted/page/290/#findComment-2058458
Spotted a white 32 Gtr on the Monaro hwy this morning around 7:45, had very stiff suspension, wide white Volk TE37's and a C-West type wing on it... looked very cool but the Asian looking guy driving it wouldnt look at me, so I couldnt give the usual nod of approval
https://www.sau.com.au/forums/topic/30059-spotted/page/290/#findComment-2060629
spotted a very hot bright red r34 near uni a little while ago. very nice sounding exhaust too. if you're reading this though mate, that area has lots of pedestrians, and giving it stick around there is looking for trouble. slow down, your car still looks and sounds fantastic. :)
https://www.sau.com.au/forums/topic/30059-spotted/page/290/#findComment-2061513
Sorry man, didn't even spot you til I drove past. Mate in the car told me off too, said you waved, but by then it was too late.
nah its all good I am only joking, it can be really hard to see through that tint, and it was raining.
https://www.sau.com.au/forums/topic/30059-spotted/page/290/#findComment-2061716
spotted a black R32 GTR going along state circle about 5.45 ish this arvo.
then at 6ish, a silver R33 gts-t going around parliment house. had wheels and an exhaust, was stock otherwise. looked very neat......
The R33 was me, on the way home from work. Where were you? It's funny, ever since I got hooked onto these forums I'm noticing every skyline I come across, than stare at the driver and wave. I'm not weird.........just sharing the love.
https://www.sau.com.au/forums/topic/30059-spotted/page/290/#findComment-2063001
i was on the forecourt of parliment house. im a cameraman and was doing a 'piece to camera' with a journalist when i saw you cruise by..... do you work at the house or just in the area? i've only ever seen 2 'lines other than mine in the carparks there.
https://www.sau.com.au/forums/topic/30059-spotted/page/290/#findComment-2063252
Are you talking around in the ministerial entrance area luke ??? if so i was out there at about 2ish one good thing is my pass lets me park right out front of the doors woot :rolleyes: those polls that retract into the ground are scary things lol
https://www.sau.com.au/forums/topic/30059-spotted/page/290/#findComment-2063309
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
