SPotted driving down pass the belco mall
Number Plates "Faith" maroon its nice
Yeah thats Pete's car, neat with some nice little mods to set it apart.
Number plates cool too "Faith - Gotta have a little" or something along those lines.
https://www.sau.com.au/forums/topic/30059-spotted/page/356/#findComment-2696251
spotted a white r32 gtr at narabundah at about 6:15
spotted a white R32 GTR heading out of jerra last night at around 8pm-ish. i waved a bit late, apologies if you didnt see it!
man i get around. i'm usually too preoccupied trying to act cool in my car so i may not necessarily notice people waving at me lol.
https://www.sau.com.au/forums/topic/30059-spotted/page/356/#findComment-2700710
Spotted Red R31 (soz didnt have time to wave ^_^),
a bunch of lines in Woden last night, White 33 out the front of lisboa (YGT 33S) a black R34 with some nice volk rimz in the carpark nearby.
Spotted Red r33 near O'malley - I pulled next to it and looked through the window, anyone from here.
Also a bunch of others that I cant really remember ^_^ :sorcerer:
https://www.sau.com.au/forums/topic/30059-spotted/page/356/#findComment-2704112
spotted heaps of 'lines today in woden. drove past a silver R33 with a GTR wing, 400R kit and a big "SkylinesAustraila.com" sticker on the rear window. i thought someone stole my car!!!
then i saw MIVEC turing right onto Yamba Dr, then spotted a white R33 with a funky rear bar turning into the JB carpark....
i was in a white crappodore with commonwealth plates, so i didnt bother waving...
https://www.sau.com.au/forums/topic/30059-spotted/page/356/#findComment-2704915
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
