Spotted a few today on a delivery run, trucks are dam fun to drive, so high up and its like driving a lounge chair.
a dark green 33 sedan near dickson (think they are a member here)
Black series 1 33 near war memorial
Silver 32 GTR parked in dickson
and pretty sure I spotted this car near old bus depot market:
http://www.skylinesaustralia.com/forums/in...st&id=87167
https://www.sau.com.au/forums/topic/30059-spotted/page/416/#findComment-3193415
Spotted a white R33 gts-t with P Plates gettin CHOPPED by my mate in his 1600 with me in passenger seat :thumbsup: on yamba drive last night.
will make a nice youtube clip too..
If u were in that nice green 1600 at about 9 that was me. In theory u would have CHOPPED me since that 16 seemed to be off its nuts and my 33 is stock- (despite my username) but i backed off at a reasonable speed when u flew past. :( Whats in that anyway SR20?
https://www.sau.com.au/forums/topic/30059-spotted/page/416/#findComment-3194069
Spotted Donnan in his car out the front of CUBE the night club checking out the guys licking his lips while i was walking to the casino :(
Must have been while i was dropping off or picking up my wife, f##k head! I do not even know who you are and you are giving me this kind of shit.
Grow up, get a life or go crawl under a rock and get your facts straight before you post this kind of sh!t.
https://www.sau.com.au/forums/topic/30059-spotted/page/416/#findComment-3194072
Just found the youtube vid, i seem like a pansy :wacko: . Love that datto tho seems to go pretty hard with the fj. Will try to keep up next time, especially if i see a camera :thumbsup: .
https://www.sau.com.au/forums/topic/30059-spotted/page/416/#findComment-3194074
your a keyboard rambo *claps his hands*
https://www.sau.com.au/forums/topic/30059-spotted/page/416/#findComment-3194115
Spotted a r32 deep blue coloured sedan, with a trojan sticker on the back, near Fishers hardware store in Fyshwick around 12:45, didn't spot you till the last second (parked) but car looked good, nice rims. Nice to see another 4 door in canberra for once :(
https://www.sau.com.au/forums/topic/30059-spotted/page/416/#findComment-3194291
