Spotted bullet32 behind me at the lights near the hospital, i did wave back, honest!
I didnt see you wave, although I did take off to get in front of you pretty quick...
By the way your exhaust note is one of the best Ive heard. :D
https://www.sau.com.au/forums/topic/30059-spotted/page/456/#findComment-3543033
R8 in Canberra? Giddyup. Saw an AM Vantage going past Russell, as Clarkson says 'that's not a car that's pornography'.
Red Lada Niva, lowered with what looks like a sb chev behind the front seats, lots of promo stickers appears to be a show / drag car.
I get the feeling we are going to see a lot of these different cars over the next two weeks with summernats on.
https://www.sau.com.au/forums/topic/30059-spotted/page/456/#findComment-3548637
