That is exactly what i saw...
Just checking; did it have dealer plates on it? And black in colour? There are a few in Australia, but as personal imports, so they can't/haven't been complied to be legally driven on our roads... BUT there is one in Canberra that has been driven about with said dealer plates...So, not that I really doubted you; it may've come across that way, but the thing shouldn't have been driven about...just yet....
https://www.sau.com.au/forums/topic/30059-spotted/page/460/#findComment-3607943
I didn't see a plate on the front, and didn't notice if there was a plate on the back. So dealer plates are quite possible.
If you check the R35 section of the forum there is someone else who claims there is one in Canberra.
https://www.sau.com.au/forums/topic/30059-spotted/page/460/#findComment-3608242
Looks like the GTR in Canberra was driven down from Sydney (lucky bastard) fairly recently. Someone else spotted it while driving from Syd to Canberra:
If anyone knows Jerry or the guys at J-Racing well, try and get them to bring the car to Shannons Wheels this March :banana: We will pretty much win that entire event if the R35 makes an appearance.
https://www.sau.com.au/forums/topic/30059-spotted/page/460/#findComment-3613256
yes it is. my suspension is the same as his 33. when i asked Chris at Inline what should i do suspension wise, he said to go and look under Bob's 33, so i did. "nice.." i said. "thats what i'll do to your car.." said chris. "awesome.." said me... :worship:
https://www.sau.com.au/forums/topic/30059-spotted/page/460/#findComment-3613770
Yep; the grey 35R is definately Bob's. And Jerry tells me he doesn't have one, which is good enough for me. Whilst the car isn't complianced, it seems a mere matter of time, tests and red tape before Bob gets to drive it on the roads. The question I need to ask him is what he's done with his daily driver 34. Would be a nice garage: 33,34 & 35 model GT-R's!
Spotted today: a black 32 GTS-T, nice wheels, well fitted FMIC, driving into Fyshwick as I was passing through. Saw the driver looking, so I waved, but it mighta looked a bit weird...getting a wave from a gold Forester! I long to be more recognisable behind the wheel of a certain white 32.
https://www.sau.com.au/forums/topic/30059-spotted/page/460/#findComment-3615174
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
