spotted a maroon r32 with FMIC in belco at lunch timish.
spotted a silver R33 with wrx bonnet scoop, huge front bar with mesh grill and mesh infront of the FMIC, 20" zenetti masqerades, standard rear bar? with huge angled upward "imfullawater" cannon on the back. not my taste but didnt sound to bad
https://www.sau.com.au/forums/topic/30059-spotted/page/668/#findComment-5834686
I saw that last weekend in Tuggers.....definitely got a chuckle out of me when I saw it.
https://www.sau.com.au/forums/topic/30059-spotted/page/668/#findComment-5834793
Think I spotted Jimmy's yellow beast on Gungahlin drive followed by a black R33 just after 5 this afternoon. Was heading in the opposite direction in the little coupe :)
Yeah got out of work a bit later than usual.
i think you're one of the few people that actually notices me getting around.
i still haven't spotted your coupe yet though.
you must be a ninja :ninja:
https://www.sau.com.au/forums/topic/30059-spotted/page/668/#findComment-5835707
Spotted a 300zx pulling over on drake-brockman dr this morning, then the driver getting out of the car as i drove past.
Engine out.
haha exactly what i was thinking as i scrolled down.
saw a silver R33 with GTR badge but didnt look like a GTR wing on hindmarsh southbound about 5
https://www.sau.com.au/forums/topic/30059-spotted/page/668/#findComment-5836440
It'll be home within 2 weeks.
This is the second longest time it's ever been off the road in 5 and a half years and I think this is going to be the most worthwhile.
Pffft snapped, he drives a 33 and a hair dressers car :nyaanyaa:
Ahahahaha oh Kat, don't you know a hair dressers car can't have more than two doors! :P
$10 says your car is back in a shop of some sought within 6 months :P
https://www.sau.com.au/forums/topic/30059-spotted/page/668/#findComment-5836459
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
