Yay I got spotted... But that morning my mind was elsewhere so only noticed what I had to so I got safely to work... *late wave*
Melly if that was you in the pink 33 with white nose you've been spotted twice, I think I spotted you (well that car) in Deakin near the mint yesterday .... if that was you, nice to meet you.
https://www.sau.com.au/forums/topic/30059-spotted/page/712/#findComment-6187105
yeah she was in Deakin on Thursday
https://www.sau.com.au/forums/topic/30059-spotted/page/712/#findComment-6187725
Spotted me with a big grin down Lanyon drive this morning boogieng like the devil was after me :D
(pay the fines later)
Nothing but Props for ESP, in particular Glen. Never ever thought I'd say something positive about canberra tuners.
Big effort and an awesome result - Safe @ lightening speed results. Talk about going the extra mile.
Props to CRD for the build - SOLID !
Props to ESP for their efforts and results in the tune. Paid a small fortune but beleive me it's worth a big fortune and more.
/end rant
https://www.sau.com.au/forums/topic/30059-spotted/page/712/#findComment-6188164
/end rant
Thats awesome to hear Richard. Hopefully i won't be too far behind you with my GTR haha
Will have the boys at ESP to thank for my build and tune
https://www.sau.com.au/forums/topic/30059-spotted/page/712/#findComment-6188203
spotted me getting wisdom teeth out. getting sedated is the best feeling ever, its like alcohol but really intense and you know whats going on, think I might still have a bit in me.
oooooow
Had mine out just over a year ago, being sedated was so relaxing! But yeah the bill hurt. Enjoy the next week or two eating ice cream!
https://www.sau.com.au/forums/topic/30059-spotted/page/712/#findComment-6190626
Thank god I have parent. I barely even remember writing that :wacko:
HAHAHAHA Zane and Mitch loved me on when I got mine out... NOT...
Some of the Sydney crew saw me too, at Superlap I was sitting on a concrete barrier and kept dropping in and out of consciousness because I was on endone so Zane and Mitch kept sticking their arms out to stop me falling off backwards... I think Shell was even there...
I don't remember much of the time...
https://www.sau.com.au/forums/topic/30059-spotted/page/712/#findComment-6190634
Yes, yes I was :D
I was lying on the grass trying not to throw up from epic hangover, and you were sitting next to me yabbering away deliriously. I remember you being super paranoid about your drugs like someone was going to shiv you for them.
There were cars or something too...
https://www.sau.com.au/forums/topic/30059-spotted/page/712/#findComment-6191195
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
