Spotted Trozzle's car parked on the road out the front of Gentech in mitchell yesterday arvo
Yerp, was getting engineer's certificate at Canberra Motor Works. Unfortunately didn't get it due to a few things (one of which is worrying lol), however shouldn't be hard to fix up. Unfortunately I foresee having to cancel the rego on my car before the lack of defect clearance does it.
https://www.sau.com.au/forums/topic/30059-spotted/page/720/#findComment-6250315
Something to do with the diff/cradle mounts is allowing the whole diff to move up/down around 10mm
Yeah you're right.. just a little worrying :/
Spotted Troy and Richard hugging each other as the sun went down over the lake. They looked to be eating takeaway.
Hope you boys had fun
Sin and his troy boy
https://www.sau.com.au/forums/topic/30059-spotted/page/720/#findComment-6250393
Batted Savs with Mayo & Choc tipped Bannanas, your Favourites. You should've come............
Gags :sick:
https://www.sau.com.au/forums/topic/30059-spotted/page/720/#findComment-6250489
Cheers Josh!
Yours had a nice tune when it took off as well
I spotted a r31 parked outside of Pedders in Phillip as I dropped my car off for an inspection
Spoke to the guy who owns it about his Rims dont know if his online here
Also spotted a Silver 33 cruising around Phillip.
Then Josh rocked up for a surprise visit just after I talked to Natrad about my constant coolant problems
https://www.sau.com.au/forums/topic/30059-spotted/page/720/#findComment-6253128
Pedders bad :down:
Rear calipers installed on wrong side and upside down. Pads on wrong way in calipers.
All new suspension installed but not adjusted. Camber out, toe out, F/R balance alignement out.
Bled in wrong order, air in brake system. Did not and would not blead ABS - WTF.
3 x returned for fixing - no luck and they had no idea.
Sir your brand new Rotors/Calipers/Pads/braided brake lines/BMC have no problems. Your car just does not stop very well and its got very spongey brakes. You should look on the internet and see what you can do to fix that !!!!!
Yes I went back and told them what was wrong and that I had paid again to have it done.
1 minute at ACT brakes - your calipers are on upside down and wrong side sir. Fixed. Felt alot better.
But these guys didnt notice pads installed correctly. Went back twice more. Sir there is nothing more we can do !!
Both of the above shops have "Brake Specialists" in their business name.
ESP identified and resolved all brake issues :thumbsup: and bled the ABS as per what you are supposed to do !
Capital steering and suspension for dialing in suspension :thumbsup: . Booked in Wednesday.
I should go get the spare key to my car and go steal it back haha?
Okay well there goes $14 for the inspection lets see what they come up with that's wrong with my car
https://www.sau.com.au/forums/topic/30059-spotted/page/720/#findComment-6253190
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
