Well it is still there... Very jealous mate. It really is a beautiful 32.
Edit: Went to get a pie because im fat and Sin goes past.. gave a wave!
Edited by Anfanee
https://www.sau.com.au/forums/topic/30059-spotted/page/775/#findComment-6625737
well i managed to spill some of the pie on my shirt -.- now i look like an idiot.
Remember Richard.... The offer is still there for us to swap 32's... I think its a fair trade!
p.s your car does sound lovely as well.
https://www.sau.com.au/forums/topic/30059-spotted/page/775/#findComment-6625873
same happend on my first rebuild, smoke throughout the workshop before I'd even been asked to pick it up.
my request to have N1 Turbo's serviced and lines replaced obviously fell on deaf ears :verymad:
left on workshop floors for over 12months and then put straight back on - FTW
Engine builder thought garage would do and workshop thought engine builder would do.
Result = 2 farked newish N1 turbo's
https://www.sau.com.au/forums/topic/30059-spotted/page/775/#findComment-6626015
Spotted a white r32 four door in queanbeyan looked nice waved but got a strange look lol probes cause I was in the soarer
Wasn't mine was it? With your black wing mirrors? Would have been my mate driving with me following in the crappy blue lancer, we had just got back from the nats.
https://www.sau.com.au/forums/topic/30059-spotted/page/775/#findComment-6629363
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
