Yeah only saw kyle at 4pm when i came back from the bottle-o..
If you want photos inside or whatever let me know we might be there over the weekend. But yes the signage out the front is sensational..
Will get you red and white ones in the new year....
Edited by ScR33m3r
https://www.sau.com.au/forums/topic/30059-spotted/page/791/#findComment-6677652
Oh oh oh - got home and spotted MLR's Silver 33 GTS-t turn up in our driveway. Wasn't expecting it but Mark was here to pick up rotors from Troy.
Damn nice 33 with an RB25/30 and a T04Z. Hauled ass at the Goulbourn SAU Nationals Airstrip run :D
Tidy tidy 33. engine bay clean and cage in the cabin
https://www.sau.com.au/forums/topic/30059-spotted/page/791/#findComment-6677675
Grasshopper Guts Green 32 GTR? with carbon bonnet on Clarrie Hermes about 12:50pm and a silver s1 R33 with blue bonnet with white stripes at Gungahlin market place. NSW plates. 1:50 ish.
https://www.sau.com.au/forums/topic/30059-spotted/page/791/#findComment-6682161
Around midday today I spotted a nice looking silver M35 Stagea Axis on Oaks Estate Road.
A few minutes later I was following a neat black 4dr R33 on Canberra Ave heading from Qbn to Fyshwick. You probably didn't notice me, but you would've seen the numpty in the Chrysler 300 speeding past in the right lane only to get stuck behind a little white Yaris (my brother) :laugh: .
https://www.sau.com.au/forums/topic/30059-spotted/page/791/#findComment-6683556
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
