OR! Tell him to get one of those new Toyota 86s! ;)
They are surprisingly cheap and seem pretty awesome, I must say I'm a big fan of them.
Not enough powah. Wait till they release a turbo version... They totally will.
https://www.sau.com.au/forums/topic/30059-spotted/page/800/#findComment-6719065
goes against the philosophy of the 86, it's all balance and handling.
Lets be honest. The only reason the old 86 made it anywhere is because of initial D. Apart from that it was a cheap shitbox that people could drift. And in todays standards of cars its not too much to ask a car competing in the market it is to have a turbocharged option. Whats the point in owning a car that can go around a corner a bit faster than your average if it cant accelerate out of it....
Edited by Anfanee
https://www.sau.com.au/forums/topic/30059-spotted/page/800/#findComment-6719200
The fact it's so underpowered for what it's competing as is the only reason I dislike them.
As Anthony said, racetracks have straights. My mate who owns one loves it, but hates the fact it's gutless below 4000rpm.
https://www.sau.com.au/forums/topic/30059-spotted/page/800/#findComment-6719202
I hear what your saying. But thats the current Toyota philosophy and is fine for your "comuters" and the regular population.
In my opinion It should be optioned up to mix it in the sports classs. Perhaps it may be left up to the enthusiasts to do this - who knows.
It's great to see you post Dan. WB :cheers:
https://www.sau.com.au/forums/topic/30059-spotted/page/800/#findComment-6719208
They should have mate the GTS 5k more and made it a turbocharged option. It's just not quite there in terms of powahhh.
https://www.sau.com.au/forums/topic/30059-spotted/page/800/#findComment-6719211
I'm not against seeing it boosted, just can't see how it could be introduced without upsetting their focus and marketing of it. besides, where better to get that boosted feeling than the gtr?
in the end, I think the bean counters will have the final say.
LOL - yeah, I comment about as much as I drive my gtr! must get around to meeting up with you guys some time (I've been sitting around for years...) :)
Edited by DAN00H
https://www.sau.com.au/forums/topic/30059-spotted/page/800/#findComment-6719218
LOL - yeah, I comment about as much as I drive my gtr! must get around to meeting up with out guys some time (I've been sitting around for years...) :)
There isn't any new cars that sit in that cheap, quick market. The 86/BRZ would completely rule it.
Edited by Anfanee
https://www.sau.com.au/forums/topic/30059-spotted/page/800/#findComment-6719221
Ay Troy - post a pic of your new awesomeness please
I HEAR HE DOESN'T HAVE A FULL LICENSE? NAUGHTY NAUGHTY!
lol bugger off you. As far as 99% of this forum is concerned, that's almost the pot calling the kettle black :P
https://www.sau.com.au/forums/topic/30059-spotted/page/800/#findComment-6719247
My 1998 Prelude VTiR has the same KW's at the fly.
Admittedly its front wheel drive but why would I buy an 86 (spose it is RWD) but other than that - meh
Haven't gone far in over a decade
Exacery. And 40k isn't cheap for a daily bash around drive lol.
https://www.sau.com.au/forums/topic/30059-spotted/page/800/#findComment-6719252
Karnts the lot of you young buggers :D
all goood.
I'da bashed him Troy for posting that but now you've reposted - LMFAO
The pic does NOT do it justice. That Bitch is smokin' hot
It handles extremely well Maaaaate. Went to Cooma nad back today :P
https://www.sau.com.au/forums/topic/30059-spotted/page/800/#findComment-6719255
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
