Spotted a black stagea with green rims at canberra avenue/hindmarsh drive intersection near fyshwick this morning. Love it!
That's me or the missus, cheers mate.
Also missus "raced" a "skyline" that was blue with big black rims that was so loud it hurt her ears this arvo in the stagea. She was cut cos she got smoked. I said what do you expect it's a standard 1700kg barge hahaha so just bought a split front/dump pipe haha
https://www.sau.com.au/forums/topic/30059-spotted/page/821/#findComment-6804715
Yesterday (thu) at 1330ish .... Leaving the Woden car park near Sth Cross club a very stock looking white S1 33 followed a few minutes later by a white 34 sporting Ps ..
Saw a FB picture of a black R34 sporting L's. :/
No soul would touch my R34 (If I had one).
https://www.sau.com.au/forums/topic/30059-spotted/page/821/#findComment-6805128
i had a 32 on my L's... twas my car lol
R32 GTR?
Different realm of cars, but a bloke I knew had a HSV Clubby R8 (VE - 2006) on his Reds. Took him 2 years to pay it off. Loaded parents :(
My Dad isn't into cars, and I try convincing him into buying something I want nice, but never works :(
On a bit more topic - Does anyone in SAU - ACT own a R35? I've seen one or two driving about (Young Asian drivers). A good m8 of mine knows a R35 owner in Canberra but don't think he is on SAU. Just curious.
Edited by Jeremy90
https://www.sau.com.au/forums/topic/30059-spotted/page/821/#findComment-6805392
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
