Spotted a few Skylines today on hindmarsh drive going towards weston
Black R32 with no wings on green wheels around 2pm
Black R33 GTSt and less then 5 minute a White R33 GTR around 430pm
While coming home on William towards belconnen black R32 Gtst had clear tail lights.
https://www.sau.com.au/forums/topic/30059-spotted/page/894/#findComment-7118464
Well... FINNNNEEE I admit your R34 GTR V SPEC II is ....okay.
What about my white 34 Jeremy?? .... Oh that's right, it hasn't got an 'R'. .... Yep I have broad shoulders, I can handle it. ....
It's ok ......
:woot::wub:
Sorry m8 - it ain't no R34 GTR Vspec II. However, since you're Bill I guess your car is SLIGHTLY better.
https://www.sau.com.au/forums/topic/30059-spotted/page/894/#findComment-7118748
