today at Philip around 5:10pm, white GTR V-spec ( black front lip ) parked beside me, I was in the video shop, saw him get out and have a little look at mine, I went to walk out and have a chat, got to the door and he was walking into the medical centre with a chick... DAMM !! haha
https://www.sau.com.au/forums/topic/30059-spotted/page/921/#findComment-7178380
Shuyin?
https://www.sau.com.au/forums/topic/30059-spotted/page/921/#findComment-7178557
Her pe's
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/921/#findComment-7178589
white 33 just now in Yarralumla, 2 doors down, hurd the same alarm as mine, thought oh I wonder if that's a skyline, he started it up, herd the rb growl! and said yep! stood beside mine with a ciggy, waved, not sure if he saw me, it was dark as hell! sounded nice as he slowly drove past! having a black skyline a night not sure if he saw minie, had a chick with him, maybe it was the same car as in phillip? didn't see the wing, did have a gtr bar, didn't notice the black lip tho ...
https://www.sau.com.au/forums/topic/30059-spotted/page/921/#findComment-7178812
On my drive home down the Barton I was following a white 34 that did a mad drift around the roundabout when turning right.
I nearly lost control right behind him as well going straight ahead.
Must have been oil on the road because we were both going pretty slow.
https://www.sau.com.au/forums/topic/30059-spotted/page/921/#findComment-7179550
