Because you can be busted for traces, but your not high, it doesnt stand up in court.
So its a waste of time and money for everyone.
People need to LISTEN to scientists. They know how sht works.
If politicians listened, they would not have wasted everyones time and money on things like this.
Scientists and engineers should run the country, not stupid the fks that we had to vote for.
And, yes you guessed right, i failed mine! While not high, so of course im pissed off.
https://www.sau.com.au/forums/topic/30059-spotted/page/954/#findComment-7388452
Aren't you allowed to have your own weed crop in ACT for "medical" purposes or something? I remember hearing something like that in ACT. ACT are really relaxed about what goes on in their territory haha.
https://www.sau.com.au/forums/topic/30059-spotted/page/954/#findComment-7388460
It's decriminalised for personal ues but not legal. As in, you can have 3 plants but the cops will still take them, you just don't get a record for it.
And yes Tobacconists sell smoking implements, as do the Adult stores in Fyshwick but not at Newsagencies.
  • Like 1
https://www.sau.com.au/forums/topic/30059-spotted/page/954/#findComment-7388510
Hahaha! Not anytime soon. LOL
Replacing the clutch next month, but don't think that will give me those killerwasps. ;)
Thinking about painting my front lip, wing blade and end caps black. Not sure yet though.
Plasti dip it. If you don't like it it's easy to get off.
https://www.sau.com.au/forums/topic/30059-spotted/page/954/#findComment-7388625
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
