I sure will Jeremy, still haven't got to meet you mate.
I still have to get the suspension changed in the front of my R34
If anyone wants to do it tomorrow hit me up :P
Should have msgd me bummed around all day doing nothing. Got quite good at removing suspension within an 1h30 ask Jeremy lol
https://www.sau.com.au/forums/topic/30059-spotted/page/982/#findComment-7517136
