boys boys boys word of warning i just got home from a ride in the black sparkles twin turbo walkinshaw and if u are along side him be careful cause this car will put up a slight challenge i cannot describe how that felt it actually hurt the Gs were that bad would love to cruise in a line that powerful it was really crazyness
https://www.sau.com.au/forums/topic/30059-spotted/page/30/#findComment-862394
Fair nuff. Hey, Kdawgboostin33, do you live anywhere near Conder? I've seen a blue Series 1.5 going up and down my street, mostly late at night...
Hey man,
Nah I live on the Northside.............I have not seen any other 33's in Bayside Blue around in Canberra. I know bout 1 R32 - Mine has a FMIC with SIGNAL on it. How is ur ride going??
https://www.sau.com.au/forums/topic/30059-spotted/page/30/#findComment-863473
spotted yesterday evening just b4 5 on william hovell dr. white R32 GTR flew past me, i thought it might have been niks but it another ride, big exhaust, very sexy dished rims (gold centres) looked awesome!!! i was gonna boot it and have a run as it flew past, but with all of the traffic it wasnt a good idea. would have ben fun though, it seemed quick.
https://www.sau.com.au/forums/topic/30059-spotted/page/30/#findComment-868981
Nik's has 3 spoke rims
- yep - guy you mentioned above has whooshed past me a coupla times as well - always around home time in the afternoon and way too much traffic..... :headspin:
There is at least two white GTRs that live in Belco - and I think there is another one that works there...I see him heading the opposite direction (towards Civic) in the afternoons
https://www.sau.com.au/forums/topic/30059-spotted/page/30/#findComment-869018
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
