Spotted last night: White skyline in civic hit a pizza delivery guy in a dihatsu charade. i was in the gun-grey skyline behind ya mate. looked like there wasn't too much damage, hope you're alright. i couldn't stop, my mates were in a hurry.
https://www.sau.com.au/forums/topic/30059-spotted/page/44/#findComment-958081
saw a few skylines in braddon tonight, purple v-spec 33 GTR, the silver 4-door 34, white 32 GTR in woden, white series II p-plater in braddon, gun metal 32 gtr, the yellow 32 GTS-T.  was a night for lines
Ditto!Skylines everywhere last night.Does anyone know who the Midnight Plum R33 is?We followed it out of Civic towards Russell Offices and when we got to the big roundabout there,it swung right towards Kings Ave.:driver must've got bored,'cause halfway 'round said roundabout,it simply f**ked off outta there like a good GT-R can...Seriously nice car!And I do believe it's got a set of gen-you-wine Nismo rollers on it....lucky b'stid!
https://www.sau.com.au/forums/topic/30059-spotted/page/44/#findComment-961355
spotted a few today,
-The yellow R33 with the 400R kit i think however i think he has hit something as the front bar was being held on with a cord its the one that has the jap stickers down the side
- Grey R33 S1 heading into monash probably about 2:30 - 3ish i think.
- White R33 again may have just been a GTS-T but it had a GT-R kit on. it was in the erindale macca's drivethrough at about 3:30 - 4ish
https://www.sau.com.au/forums/topic/30059-spotted/page/44/#findComment-961804
I was parked in the tammets mobile servo car wash place. Had my skyline parked next to a mate's 180 with an RB25DET. we had some fun darging and cruzing round.
https://www.sau.com.au/forums/topic/30059-spotted/page/44/#findComment-961844
Spotted: Jay95R33's stagea, in his driveway. so jealous.
Also a maroon S1 R33 filling up at the servo near my joint in Kaleen
Wah! Awesome Jay! :rofl:
You've got to bring it out so we can take a geeze :(
That's it, organising a meet/cruise soon :)
https://www.sau.com.au/forums/topic/30059-spotted/page/44/#findComment-961995
hey justin, was that with chris' new 180? i saw both a 32 and 180 cruising at one point
Yea man, we got bored and did a few laps, I was in civic sat night too, did anybody see me? I was parked infront of insomnia
https://www.sau.com.au/forums/topic/30059-spotted/page/44/#findComment-962536
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
