  • Replies 90
well its alll good
i put the flush in and ran the car
the ticking stopped and i took the oil out and replaced the filter and put a additive as well as new oil in it so it will clean out the bore and its fine nw
im so fkn happy its driving fine and like nothing happened
thanks for the posts guys it was informative and funny at times
have a mad xmas
well its alll good
have a mad xmas
What flush did you put in the car? There is nothing you can put in your engine that will melt/disolve porcilain...
If it's stopped ticking... dosn't mean it's fine.
FFS! at very least get a compression test done.
Paying someone to look at it is relativly cheap. Best case- you pay someone a couple hundred bucks get a compression test and to put a scope in and check it out. Worst case- you dive it around till it it destroys the head, bore, piston... then little bits of piston/bore/valve do get into the oil and get sucked through the engine. Total loss.
$200 or $4000 ???
Get the fattest piece of hose you can get through the plug hole and still wiggle around, tape one end of the hose to the most powerfull vacuum cleaner you can find hose , empty the vac before you start so you can see what you've managed to get out , now , shove the taped on hose down the plug hole n start vac'n and wigglin .
  • 4 weeks later...
When I changed my spark plugs the other day I noticed the spark plug from cylinder 6 had some porclin from around the tip broken off.... not sure when this happened but im guessing it happened when i accidently boosted it to 1.6bar a few weeks earlier.... I was in second and saw the needle go past 1.5 n backed off straight away n i think it detonated which in turn caused the plug to break :P
Im guessing the damage has already been done :D
anyone else have this problem?
detonation from overboost wouldnt break a spark plug.. they break either from force, or from excessive heat then force.
in other words you smash them with a tool or something, which is alot easier to do when theyve been baked.
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
