about 2 months ago i decided to get the turbo removed from my rb25det, due to p plate laws.. after getting this done i discovered the car does not have anywhere near as much power (sorry all the people that advised me against this i should of listened and you were right), in fact the compression is so low that my girlfriends barina has more up and go, so about 2 weeks ago i decided its time to stop embarrasing myself and put the turbo back in. i bolted the turbo in no problems at all, took me bout 20 mins i thought it would be easy, but i failed to take into consideration 2 copper pipes coming out of the turbo its self and a thicker (screw on) pipe, im not sure where the 2 copper pipes go i cant find anywhere around the turbo area where they would connect to, also they look exactly the same and (apparently) they do different things (one for water one for oil) so i wouldnt want to get this wrong and do some permanent damage to something. i found the spot where the thicker pipe screws onto but i could not locate anywhere to attach the skinny bendable copper pipes around the area where the turbo sits, i do have car ramps if its easier to get to from underneith.. surley someone on this forum would of done this themselves or know of someone who has done this before, would really appreciate a little help.. thanks..
this is what is in place of the turbo at the moment
in the photos below the RED circles are the copper pipes that im talking about, where i dont know the location of..
the GREEN circles are another thing, in the first photo im unsure where that yellow rubber tube goes as there is no location that i can see around the area of the turbo where it would plug onto, in the second photo theres also another cut off yellow rubber tube that has been cut off and had a screw put in it to prevent flow behind the block near the clutch fluid bottle, i dont know what this goes to either, if anyone can help thanks very much..
https://www.sau.com.au/forums/topic/300900-putting-a-turbo-back-in/
  • Replies 118
Perhaps you should take it to whoever it was that removed it, and get them to re install the turbo.
The big one at the bottom is the oil drain, the one on the opposite side of the housing to it, is the oil inlet.
The remaining pipe will be one of two water lines, but there should be two of them, one inlet and one out let.
The hose in the green circle is a boost line that activates the wastegate actuator. I'd say it should be connected to the one by the clutch reservoir that's been sealed off with a screw.
both of those copper pipes attach onto the block, the oil line (the one with the curl in it) sits towards the middle of the motor - the water pipe shown sits towards the rear of the motor (when you attach the bracket for this, it should line up to its location). there is another water line that wraps around from the other side of the motor.
here are pics ive got of mine, they arent the best but i hope it helps:
post-13452-1261362245_thumb.jpg post-13452-1261362263_thumb.jpg post-13452-1261362280_thumb.jpg
One near the clutch fluid is the nipple that should run to the factory boost sensor, really no need for that one to have been disconnected.
The yellow hose running off the wastegate will need to go to the factory boost solenoid which is behind the intake filter box. From memory the solenoid isn't a simple in/out configuration and had a t piece thrown in, just go on ebay and get a $30 turbotech boost controller instead.
And yes you'll probably need to drain oil and coolant before removing any blocking screws from the block.
Edited by nicr4wks
Unless that nipple is running the wastegate and the solenoid has been by-passed for some reason.
Wastegate sensor coming off the plenum after the intake throttle on the stock setup would be a little unusual, but then again wonders never cease  :)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
