Jimbo2000 What's your opinion of the E-Boost?? does it spike at all?? I've just finnished wiring mine up but will be a few days befor it gets driven.
EMS have boost control...but not sure if they can use the factory solanoid
  • Replies 41
Even people with top of the range Motec ECU's still have a seperate boost controller, some even the SAFC aswell. Alot of supras do this in america, especially in their supra movies. I guess they have lotsa money too :cheers:
Reason why most aftermarket ECU has separate boost controller is the extra tunability. Even Apexi PowerFC's boost control option (extra few hundreds of $$$) is good, however still not as good as its sister product, a stand alone AVC-R. Not in terms of quality or operational but in flexibility and tunability.
nah its good like that, no spikes, just watch the digital readout climb all the way and sit there.
i'm more than happy with it, just get someone who knows what they're doing to tune it, took it to a somewhat respected workshop in syd and they'd either never tuned one before or they were just really crap. actually had to come back later to give them the manual.
Hmm... problem is not many standalone ecu for that price incorporates everything. Not sure about Wolf but even PowerFC DOES NOT have a boost controller embedded, it is still an option add-on that you need to buy.... so as far as I know there hasn't been any so far... unless u can show us which aftermarket ECU has boost controller included for that price.
wolf3d has built in boost controll which can be accessed through a laptop (dont quote me i could be making stuff up here :cheers:)
i can do avcr tuning - guaranteed to come on stonger, earlier =)
the only issue i have with the avcr is it doesnt fit into a factory DIN. so i leave it in the glovebox.
I have mine mounted where the ashtray use to be. Once you know what the broad brush strokes are for setting up its actually pretty easy. I can get mine to hold stable boost without spiking at 1.1bar when the std wastegate pressure is 0.65, so can easily to the job. I think if i want to run any higher though she will start to perhaps struggle and ill have to wind in the wastegtae to about 0.85bar to endure it is stable at 1.3bar.
Get whatever you like the looks off, and just ensure it is setup correctly as they all work well when installed properly.
...oh what mad bugger would buy a Motec only to use an SAFC. A boost controller i perhaps understand as that frees up an output on the ECU to be used for other things, but an SAFC on an M48 let alone M8???? I wish i was the workshop selling this guy stuff :cheers:
...oh what mad bugger would buy a Motec only to use an SAFC. A boost controller i perhaps understand as that frees up an output on the ECU to be used for other things, but an SAFC on an M48 let alone M8???? I wish i was the workshop selling this guy stuff :P
Selling me stuff? are u talking to me?
I see it all the time, probably 4-5 cars now.
I know they do something with it, not sure why, but they do.
No wasnt referring to you specificly, but the cars you have seen.
Just saying if i was a workshop id love to have clients who let me sell them a fuel/ignition ECU like Motec M8 (you did say top of the range) then only to sell them an SAFC as well.
Doesnt make sense, like i said the boost controller frees up an output to be used for something else, but it doesnt make sense to use an SAFC on an ECU that offers superior control over fuel and ignition.
I know, i never said they were smart ;)
Ide assume they had the SAFC already when the got the other ECU etc
It would allow you to change fuel settings instantly, where in full EMS you can only change maps that have set setting.
Or something like that
i had a TurboXS bleed valve on my S13, it had full exhaust and hybrid cooler, stock turbo SR, the bleed valve worked quite well for 1bar, then i got a 2nd hand Trust/Greddy Profec B (spec 1) for it and it boosted better and for a bit longer, when playing with the boost response knob (forget its exact name) but really didnt make too much difference really just coz of the stock T25G being out of its effeciency pretty easily and always wanting to bleed boost.
in my DR30 it has an older style HKS EVC and i find this to work really well on this car. running about 1.1bar and it goes up and stays there really well, never ever spikes or jumps around. i have catback exhaust (soon to be full =]) and a small FMIC, stock T3 turbo (FJ20)
Heres some info for all you.
The profec b spec 2 is useless with an external gate.
is that why u asked me abt hks evc today?
well, in hks evc there's a switch at the back of the control unit to select either internal/external wastegate. didn't the profec b spec2 has somehting similar?
maybe hidden in somewhere in the webs of its electronic menu or options, unlike a swithc or something.
Profec b has a seperate intake into to the solenoid for an external gate but the solenoid aint so great with the ext gate.
HKS EVC 3 or 4 with the stepper motor works the best with ext gate.
hi there.... can i get some help from you guys?? i have just installed a Blitz Dual SBC Spec S into my R33 gtst and was wondering what is the settings you guys have in it?? i want to increase my boost up to 0.8 bar.... any help would be apreciated... thanks.. :headspin:
cheers :D
Jackson :Bang:
    • I normally run with I think a 10mm, and definitely use the second handle you can add to a drill. They hurt when they bins up!   For the crush tube, once all subframe is clear, I'd try some stilsons and see if I can get it to start to twist.
    • Probably because they couldn't, because the use of the variable resistor to create a "signal" in the ECU is managed by the ECU's circuitry. The only way that VDO could do it would be if they made a "smart" sensor that directly created the 0-5V signal itself. And that takes us back to the beginning. Well, in that case, you could do the crude digital (ie, binary, on or off) input that I mentioned before, to at least put a marker on the trace. If you pressed the button only at a series of known integer temperatures, say every 2°C from the start of your range of interest up to whatever you can manage, and you know what temperature the first press was at, then you'd have the voltage marked for all of those temperatures. And you can have more than one shot at it too. You can set the car up to get the oil hot (bypass oil coolers, mask off the air flow to oil coolers, and/or the radiator, to get the whole engine a bit hotter, then give it a bit of curry to get some measurements up near the top of the range.   On the subject of the formula for the data you provided, I did something different to Matt's approach, and got a slightly different linear formula, being Temp = -22.45*V + 118.32. Just a curve fit from Excel using all the points, instead of just throwing it through 2 points. A little more accurate, but not drastically different. Rsquared is only 0.9955 though, which is good but not great. If you could use higher order polynomials in the thingo, then a quadratic fit gives an excellent Rsquared of 0.9994. Temp = 2.1059*V^2 - 34.13*V + 133.27. The funny thing is, though, that I'd probably trust the linear fit more for extrapolation beyond the provided data. The quadratic might get a bit squirrely. Hang on, I'll use the formulae to extend the plots.... It's really big so you can see all the lines. I might have to say that I think I really still prefer the quadratic fit. It looks like the linear fit overstates the temperature in the middle of the input range, and would pretty solidly understate what the likely shape of the real curve would say at both ends.
    • I got a hand held bisssel one and it's a piece of shit. Doesn't work for more than about 5 seconds. So much so that I nearly refuse to believe any wet dry vac actually works or has enough suction to clean the carpet of a car. I'm discouraged as all the good ones are $300+ for an unknown result. I saw MCM did a Ryobi video where they use this thing: https://www.ryobi.com.au/products/stick-vacuum-cleaners/18v-one-hptm-brushless-spot-cleaner-tool-only Anyone have any experience actually using a tool like this when not paid to showcase it?
    • That could very well be the thermistor, but the ECU only sees Volts. VDO don't seem to provide a 0-5 volt curve, only the resistance curve.... (or line).
    • Yes. Probably, given that there is only access from the bottom end of it, go with a drill bit. Don't start too small. 7 or 8mm is probably the right size. You want something that can make a big enough hole to do some damage, but not so bit that it clashes with the steel or binds up and breaks your wrist. A slow speed is probably a good idea too. Once the rubber is destroyed, you then have to get the crush tube off the stud, which will be the whole heat/oil/cutting exercise all over again, but this time with the need to strictly avoid damaging the stud (any further than the corrosion might already have done.
