ive got my wii chipped and hacked and it ive got a gamecube emulator disc with a trillion games on it
now the wii works ok, the original games work ok etc but when loading the emulator disc the screen wobbles left to right
i notice when the gamecube disc boots it comes up with its GCOS bios screen (blue) and its got at the bottom NTSC BIOS
the obvious assumption is my tv doesnt support NTSC
its an LG plasma 42PG20D got it about 1 year ago
so when you laod the gamecube disc and choose the emulator to boot (ie snes etc)
it loads that and then you select your game etc and its fine
all this while the screen wobbles left to right rapidly
then randomly the wobblying goes away and you can continue playing
other times you have to constantly reboot the wii, try again and you get lucky and the wobbly stops within a minute or so
ive tried to replicate it over and over, and cant make it consistent, its just random each time, but usually stops wobblying within a 1-2 minutes (but not always)
the guy who chipped it tested it and said its fine and that the disc is ok
and he said the tv is at fault
sure - so has anyone else seen this before? the wii is connected via normal composite into the tv
https://www.sau.com.au/forums/topic/301264-hacked-wii-randomly-misbehaves/
ok so after some messing aorund ive tested the wii on my projector
and it works fine first shot
so the tv is being stupid
but i dont get why mid flight if i do nothing, it randomly supports NTSC
or the WII changes to PAL ?
any ideas why it randomly stops wobblying?
yeah i get that and understand its different
any ideas why the TV would randomly switch between not supporting it (wobbly left to right) and then supporting it (no wobbly) without user input
Nintendo did a heap of security on their games in the past (not sure now) to do with locking the games code if the machines region did not match the console it was on. That might explain the GCN games, but SNES due to being completely emulated is beyond me.
ok i figured it out, the wobble (side to side) is from the emulator giving a poor mode of 50/60hz (or my tv not supporting it correctly)
the game iso disc i have is a mega emulator one and they all the issue, even the bios does, so id say my tv doesnt like a mixed 50/60hz mode
so i messed around and started using the homebrew channel (ive never used it before)
turns out the homebrew browser lets you access all the hacked apps and emulators. i always thought the homebrew browser, was basically a ported mozilla to the WII so i never used (why would you?) - but it turns out it opens access to the hacked apps and emulators library
so from there i installed the snes, nes and sega ms emulators and they work fine, i had the side to side wobbly issue with the sega ms emulator and it had an option to change from 50hz to 50/60hz and 60hz. the sega ms emulator on the wii emulator disc must be an older version and doesnt let me choose. so all good
in sumamry
dont bother with discs if you want hacked emulators etc, use homebrew channel, then homebrew browser and install whever you like
another nice bonus if you do this is you dont have to use the game cube controller, the normal wiimote works in all of the emulators
I've been using Homebrew Channel for a while now with USB Loader and a dedicated hard drive plugged in to the Wii with my backed up games on it.
Have you got Neogammer installed on it too? That should load the discs..
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
