  • Replies 230
was waiting for your car to pop up blags... :(
joeyjoe did your rear wheels go straight on ? whats the size again and you dont have to run any camber?
not bolt on... i refuse to run camber as the car has 323rwkw
i'm runing 18x9.5 +25 w 245/40/18 nitto NT05's
the camber is set to be flat on WOT, cant remember the exact numbers
guards had to be flared
Does anyone here with these "fitments" actually track their cars?
and by track I dont mean drift?
Its all very well bagging out people with safe / conservative offsets..but if you are jumping ripple strips having a bee's dick of clearance to the guards and 10deg neg camber just isnt going to work, nor is having a 215 tyre streched onto a 10" wide rim.
*awaits all the "hella flush" fan boys to say OMFG your car is so shit you have +22 offsets on an 8" rim with 235 tyres, you should get 50mm spacers and 185s!!12131!!ty*
when mines finished i will and not just drift.
17x9.5 225 stretch, having bee's dick clearance on neg1 on rear all the way through suspension travel. and neg2 up front which i believe are realistic numbers.
camber and stretch is not wheel fitment. you have to think realisticly when doing it, running something stupid like neg4 or something on the rears just to tuck em is retarded. however when you look at it / \ is baller lOL, but not practical
wheel fitment is rim size, tyre size, ride height, wheel alignment, guard work. the propper hella flush cars are defiantly not what you have described above, majority are show cars and yes some are impractical, however search up fatlace and see that he drives his s14 hard with fitment.
and one thing fitment isn't is SPACERS.
couldn't have said it better!
when mines finished
How is that progressing BTW?
Agreed with Dave, lotsa guys think epic stance is about stretching skinny tyres on dished wheels with camber and suspension height dialled down stupid low.
motor should be going in next week, got a bloke coming to make up some solid brake lines. he will be the first person to touch my car other then myself, its a big step :(
look on Secret Drift you'll find my project log.
still got the ceff box?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
