So yesterday arvo I was driving from my place to my GFs place up the Bruce Highway. It was raining pretty heavily but thats no problem. But all of a sudden the Stag lost power and the turbo whistle/whine went realy high pitched. On back off insted of the turbo plumback noise being a nice Chhhhhh noise it was more of a short higher pitch chh. At first I thought the turbo may have sucked in a bit of water n as a result died, so I slowed down and kept it off boost, and continued on to my GFs place (seems I had to get somewhere and by that time it was closer to her place). After a few ks though (5 or so) the problem went away and all is back to normal. So now im thinking it may have been starved of oil, as I just recently (ie.christmas eve) did a oil change and decided to try Mobil 1 0W40 (changing from Castrol Edge Sport 0W40, Which I have had no problems with what so ever). After the oil change I did notice the engine was slightly noisier n there was more vibration. So I was going to change the oil back anyway, n i have new oil sitting in the garage now.
But does anyone have any ideas of what the problem might have been?
Agree with my prognocis? Disagree?
I know its a hard one and my explanation is not the best. If it helps its a RS FOUR S.
All help is appreciated.
Thanks
Mattye
https://www.sau.com.au/forums/topic/301638-bit-of-a-problem/
Thanks
Mattye
Hmmm, I'm guessing that if you're still using the standard turbo, it might have spat a ceramic blade (or part of one)... If you want to investigate, then when the engine is cold one day, pull the cat converter off and see if there are any fragments of the blades in there.
The first description sounds like an induction hose blowing off. Although that doesn't explain why it feels fine now.
Is there a small longitudinal split of one of the intercooler hoses that perhaps is holding shut when the engine is cooler? Check all the intercooler hoses and clamps.
It doesn't sound like an oil issue at all.
I went thru a similar episode after changing plugs. I dislodged the intak to the turbo and had similar noises. I thought the turbo had packed in. Pulled it all to pieces only to find the loose hose. Replaced the two broken manny studs and the two that broke getting it apart and I have a spare TO3.
I agree, check ALL the hoses first.
yeh i dont think theres a split as its driving perfectly fine as if nothing ever happened, boosts fine and drives fine. just changed the oil again. will see what happens. n ive given it a decent drive so it was up to opperating temp. i think its just one of those things. hopefully it doesnt happen again.
So it happened again bout 20 mins ago, again in the rain. its got me stumped. i think maybe im gona have to just pull everything apart bit by bit n put it back together. the turbo was making more of a whoooo noise by the way. maybe water is geting in a crack or split or somewhere where the seal had diminished.
what he said, stock is 7.5w30, then you add one weight rating every 100,000kms (only need to change the latter number) => 0/5w40 for most stageas
why would you need to put thick oil in motors with such good tolerances from factory and still have hone marks when the motors are pulled down?
Ive never heard of going down after 100k's? Maybe thicker as it gets older?
Its just interesting as the oil grade i was told to use is no where near the factory quoted stuff and the motor is still fine after 160k's and oil's clean as each service.
Of the top of my head i cant remember exactly what it was, will have a look 2moro as i need to get some more as its due for a service again.
Edit: just looked in the garage have been using a 10w40 mobil, so not that far off, my bad, have dirty SR's stuck in my head not RB's.
Edited by msports180
thats sweet, at that sort of k's 10w40 is fine, you could use 0w40 but it doesn't make much difference
as to the original problem, i'd say its water in something electrical
do you have a pod?
I use Nulon Fully Syn. 10W/40 with Nulon addative. It has never given any problems. The addative is amazing in the amount of noise it reduces. I also use the addative in both R30s and the S13.
Edited by 66yostagea
Whats the addative? I was thinking of sussing out an addative, but i belive Castrol already has one in it. And I'm a bit of a Castrol fan. :down:
Also a bit of an update. I talked to a mate who's pretty good with RBs, he's also building my mates RB30 for his VL (so I trust his oppinion). And he recons its probs electrical (as pipster11 has already said). He said specificaly to check the ECU for water. So I've bought some electrical spray and I'm gona spend the arvo pulling plugs etc apart and giving them a spray.
Edited by mattye
Whats the addative? I was thinking of sussing out an addative, but i belive Castrol already has one in it. And I'm a bit of a Castrol fan. :D
vl's leak water from the bottom of the windscreen and it dribbles onto the ecu, thats holden for you so i doubt its that
water could be getting forced up at highspeed into some wiring, slow down and the water doesn't reach - just my theory anyway
giving the plugs/connectors a good clean cant hurt anyway
Thats actually why he said to check.
Pulled the MAF Sensor off yesterday. She was bloody dirty so gave her + connectors a clean. And I have to say, even if it wasn't the problem, a clean MAF makes a difference. :(
Had another look around the engine bay whilst it was running. Didn't spot anything. Thought i found a leak on one of the IC joins, but i think it was my imagination. lol :/. Gave it a tighten anyway.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
