ok everyone ive got an r32 gtst with a 3 inch exhuast, decat pipe and large cannon at the back, i think the brand of the system is trust, it is loud and i need to make it quiet for defect clearance,
i have got a cat to put in it so that is that sorted but i still will need to quieten it,
i heard of using a plate cut to the size of the flange at one of the joins with holes drilled into it to limit flow
anyone done this before?
also any othger ideas?
im talking cheap/easy/DIY stuff
cheers
https://www.sau.com.au/forums/topic/301960-silencing-exhuast-how-to/
You can get a silencer made up for the muffler but make sure it is welded in not bolted in or they can knock it back saying it can be removed and not pass it.
Or
Get you mechanic to fabricate a Resonator in the exhaust system.
Or
Get the stock R32 GTS-T exhaust, put on a compliance cat (non high flow) and fabricate a Resonator if needed to lower the dB level as much as possible.
Once past, return back to how you want it.
1x Cat
2x Mufflers, and i dont mean cheap ones. you are looking @ $400-$600ea.
No big cannon mufflers
No 'hot dogs'
No decat pipes.
You should be smack on legal. Fix it right the first time, get the exhaust made so it is quiet.
Had a stupid loud exhaust on my old car returning it back to standard made it so much more enjoyable (although was non-turbo car and only a cat-back exhaust so negligible performance gains/losses to be had). Want to get an exhaust for the 34 but wanna keep it fairly quiet unless of cause i'm going WOT and higher revs.
Similar question, I have an RB30DET with full 3 inch straight pipe from the turbo back to a 5 inch HKS super dragger muffler. I went to the exhaust shop today to ask the same quesitons but they were closed, would adding just a single resonator in the middle of the exhaust system make the car quieter and sound a bit gruntier/throatier/deeper? I want a nice growl but it needs to be quiet to pass a warrant of fitness.
^ forget it. Hotdogs etc etc, pointless on RB's. I've not seen one that does any good.
Piss of the cannon. Put two decent 3.5" mufflers on (might as well increase your 3" to 3.5").
Mine really does sound quite nice under load. Just cruising around, you can barely hear it as im sure most Vic people that have seen it can attest, it's not "camry" quiet, but its as quiet as a HSV or similar just putting around, yet gives a nice little growl when you get up it a bit.
I tried forever adding/changing mufflers and resonators on my old S15 to shut it up, and all efforts were pointless. Under advice i gave up and got a HKS silent power catback. Best move ever, stock sound until 4.5k, and nice growl up high. Not exactly ghetto fix, but it is a quality long term fix. The Nismo item is very similar in nature on my RB26, very impressive for a cannon.
Cheap way out is to flange the rear and add a large oval bodied muffler (2.5" even better), may not look pretty, but you should pass with that.
HKS Hi Power "Silents" On RB's are not silent at all. And IMHO, the lower the RPM the louder it is.
I have one on my RB25, and its far from quiet. comparing it to stock sound would be like comparing black to white.
I've got a quality JASMA exhaust on my R33, its silent throughout the rev range. Has 2 mufflers and a cat, plus 3in piping. Thats one option. Otherwise, my mate had some success with putting some plates in his exhaust to take it over the pits.
The HKS silent hi power is quite silent on most car models including most skylines EXCEPT for R32 and R33 GTR/ GTS-t
for some reason the exhaust inner diameter for these models is 95mm, for every other turbo cars they're only 85mm or less
Wow i actually never realized that.
I never measured mine, but it doesnt look like it has a 3.7inch inner!
Could be wrong though, id have to measure it. Sounds massive!
Edited by gotRICE?
the first time I threw a super drager type rear muffler on my straight pipe ( was called 'megaphone' no idea what brand), and it was kosher, second time went a second hand JASMA exhaust - thinking about buying another reasonably loud exhaust, and swapping over as need be.
yeah it does actually, I've measured mine..
the diameter gets larger as it goes to the cannon, 3 inch from the cat to the hotdog, then 3.7 from hotdog to the square flange (longest section), then 4 inch after the last flange...
The HKS silent hi power for EVO, R34 GTT/GTR, silvia turbo are only 85mm all the way... and they're really quiet in comparison
ok so thanks for all the replies, i am aware that a muffler will quieten it,
but i am looking for a more cheapskate approach,
i have heard mixed ideas of perferated plates and such anyone done this beforE?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
