I'm thinking of using slicks soon but realised I know nothing about them like size (will fit under our skylines), brand, do you have to use front runners and what size rim people are using
I heard you can use a Ford chaser rim which would be a very cheap option but am not to sure if this is true any info would be great and handy to all
Thanks Brett
https://www.sau.com.au/forums/topic/30218-slicks/
OBHAVE from melb has run a 9.8 using a rb25. From what i know he did a 10.3 with 430-50rwhp thats auto.
Manual is the creatd motorsports black one from melb which was a 11.16 @ 126mph.
Both cars i believe had gutted interior and full slicks on 15inch rims and front runners.
Also 16inch au rims do not fit. They hit the brake clappers though yes they are the same stud pattern. I tried this.
Buster, was your time on nitto's? or standard st tyres and what mph did you get.
https://www.sau.com.au/forums/topic/30218-slicks/#findComment-614818
I run nittos as standard street tyres every day of the week as they are only a semi slick radial tyre
At the end of the day no different then the Dunlop DO1J, Falken Azena, Bridgestone Re540 semi slicks that people use for street/track work ie a radial tyres though the nitto is better suited for drag due to the higher sidewall then the other semi slicks I've mentioned
I ran a best so far of 11.8 @ 123mph with a 60ft of 2.0, I have ran a 60ft of 1.8 at lower boost but haven't been able to get the launch right at the higher boost level yet
We're lucky enough to have the new drag strip opening soon which will mean we'll get a fully prepped strip which should help a bit as I do kick sideways a touch going into 3rd and 4th on the part of the strip which isn't treated
Back on track though do you know anything about slicks?
https://www.sau.com.au/forums/topic/30218-slicks/#findComment-614875
    • Only if you do not You will not be able to drive it with any serious load without risk of it pinging, which will either slowly or rapidly kill it, depending on how bad it is.
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
    • lol already been put in temporarily 3 years ago
