Pics from SAU Christmas Beachside Cruise/BBQ - 21/12/03
  • Replies 78
i was surprised by the number of ppl that tried to piff the vortex at your head james... maybe it had sumthing 2 do with me tellin em they got free membership if they hit u :D
4 is nassir I think I dunno I can't remember his name properly, he brought his son too.
12 is RS73 is Rianto
19 I dunno who but I think he came with Raikkonen
13 I think was Ash's mate
My arm is sore! Damn you vortex, I know what i'm getting for Xmas! And damn, forgot to grab a SAU sticker, I blame vortex again! And thankyou James for posting the pic again with the list! much easier! And also thanks for creating my first thread Shan!
autotrust
your 4 door looks mad....
:cheers: Thanks man, The kit has taken a long time to get on my car, and I would like to take this opportunity
to thank Craig at www.j-spec.com.au :inlove: for hunting down the Genuine Impul R33R kit in japan
and hunting down the Impul RS rims that are soon to be fitted.
Also thanks to Matty and Jezza at
www.pulseautostyling.com for fitting the kit.
Power to the 4 door!!
oh that's it.... the zap is gone... or better yet i'm gonna replace it with a ghey one, so all your posts will have ghey smileys in em.
Just wanted to say howdy ho!, Sorry i couldn't come to the BBQ, looks like i missed out on some fun!. Anyways, was a real thrill to finally see a TV2 R34 GTR in the flesh, such a beautiful car. Hotsky, new car looks absolutely tops, are those rims Team Dynmaics K2's?
Yes, as with everyone else, the 4 door looks very pimpilicious, was more than happy to stop traffic on Beach road to let u out of the car park there danny! :D
Now shan, u'r supposed to be all responsible and stuff being high up Vic person of SAU, and here u are pretending to be Takumi and ripping up some dori dori in the red bluff car park!! ;) I saw that!! hehehe, did look cool tho...
Anyways, my name is Daniel, nick is 'chinny'. My oakleys are a permanent fixture when i'm outside so i'm pretty easy to spot, shan remembered the post! :).
oh and didn't want to over-shadow all u guys at the car park, by bringing my Pulsar into the mix, i thought i'd let u guys have ur time in the spotlight :)
Anyways, hopefully i'll make it one day to a cruise with me own 'line!
cheers
Thanks chinny that was a nice parking manouvre to let us out!If you make it to the next cruise make sure you have a good throwing arm for the vortex, Iam STILL sore damn you vortex :zap:
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
