hey guys was refereed to this part of the forums for my inquiry
original thread: http://www.skylinesaustralia.com/forums/Bu...se-t302945.html
basically looking to buy a 1993 model r33 skyline turbo, looking to take out the turbo so its p plate legal in VIC
heard stuff like the car not running without the turbo blah blah, just wanna clear things up
oh and was wondering if this is possible and how much will it cost all up if i could do it?
thanks again guys!
https://www.sau.com.au/forums/topic/303174-r33-1993-remove-turbo-help/
mate i personally wouldnt... i have heard on here that the car will be massively underpowered... gotta change alot of things aswell
if you want specifics.. read this whole thread mate:
http://www.skylinesaustralia.com/forums/Co...-N-t116272.html
cheers
"u cud swap with na pistons to bring the compression back up, whack a na chipped ecu or a gts link ecu in her, and replace manifold with extractors. or instead of pistons - maybe a really really thin head gasket, deck the block or the head a tiny bit.
injectors should be fine with a chipped/aftermarket ecu and obviously you would need a retune
car will drive like a total slug without the re-tuning otherwise.
its alot of work - an RB25DE would be a cheaper option to whack in her, or RB30DE but since u said ur p plate.. im not sure i dont think u cud do that man
if you went down that road of getting an RB25DE in her.. you would also have the added bonus of the bigger turbo brakes that people long for :happy:"
^^^ pretty much a quote from that above thread...
Edited by noely1
One image to sum this topic up
So its definately possible. But the results are "epic fail".
If you need a Skyline. Get yourself a Non turbo 33 or 34, Get some coilovers, sway bars and a quality catback exhaust. Then save like mad to buy yourself a GTR for your 21st Birthday.
My 2c.
Luke
As said above.
BIBLICAL fail.
Your spending more money than the price of an NA buying a turbo. Spending more money to to remove the turbo. Results are worse performance than an NA at almost twice the cost.
Buy an NA and sell later/turbo later/buy a 34 NA
thanks again guys!
I was just reading in HPI magazine somewhere, that even if you remove the turbo the car is still essentially registered as a turbo car because of its make...so technically still illegal...
Sounds weird i know...but just check b4 you dive into it....personally id get the 34 :)
Edited by faggywaggy
haah u can buy my 34 if u want :D i gotta part ways with it :/
but yeah man... turbo'd r33's are going for cheap these days.. cause the n/a versions are more expensive as the P Platers are getting into them... so if possible keep teh turbo til ur off ur p's or something and save up and get a nice N/A 34 or whatever u like..
if not then depending wat mods u have.... u might i have my doubts... just be able to get a r34 n/a if ur lucky with the money u sold ur gtst for bro.. something to think about i spose
Edited by noely1
" don't bother with an N/A Skyline, it's like buying a 4 cyl Commodore "
only alot sexier... plus some N/A skylines beat stock GTST's?? My friends R33 N/A beats GTST's on the rare occasion.. they're usually stuffed or completley stock.. still an achievement... runs early 15's to mid 15's respect for the non turbo's lol :D
commodores would run 16-17's wouldnt they? not sure..
i said my friend... not myself...
hmmm doesnt matter if they're shit drivers or the cars are stuffed... still an n/a is beating them... and yeah a VN does beat a n/a not by much?? big 3.8ltr vs 2.5ltr they put up a big fight...
we all start somewhere... im suree if he could he would drive a turbo no doubt, as would i.. gotta pay respect when its due dude
Edited by noely1
Yep that is exactly right. This is the one thing most of these young guys don't understand when talking about "taking a turbo off". This does not make the car legal. The car is complianced and registered as a turbo car therefore it is irrelevant if you take the turbo off, still illegal to drive. (might sound a bit stupid but thats the case).
The only way i can think of making it legal (at least in QLD) is going to an engineer, getting it mod plated for not having a turbo, then re registering it as a non turbo. This still might not be legal i dunno. But if it was it would be the only way to do it and really if your going to all that effort, for f**ks sake just buy a non turbo GTS.
only alot sexier... plus some N/A skylines beat stock GTST's?? My friends R33 N/A beats GTST's on the rare occasion.. they're usually stuffed or completley stock.. still an achievement... runs early 15's to mid 15's respect for the non turbo's lol :(
mid to low 15's is that all? my old v6 magna with just a cat back exhaust ran high 14's and it's a fwd family car, LOL
and the only reason a 2.5L skyline can keep up with a commodore or a falcon is because of the gear ratios. give them the same gear ratios and the commodore and falcons would kick the arse of a NA skyline and probably even give a mild turbo skyline a run for it's money.
yea, please listen to other posts mate, either just get a na wether it be 32,33,34 and save ur coin till ur 21st bday n get a gtr, once u get a gtst, u want a gtr so just get one of them straight up. :P
go with a 5 speed vs commy or somethin and just save ur coin n enjoy thrashin the commywhore around then get a vspec :OOOO make the panties drop then.
In sydney, aslong as the car isn't turbocharged its legal. Doesn't matter what its registered as, my mate went through the same process and he wasn't hassled for it....still registered as a GTS25t.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
