Next Friday, 15th of Jan. time ? they close at 11:30pm look at it around 7-730 ? please let me know for sure if your coming, so i can book, place fills up real fast.
where: Shark Fin, http://www.sharkfin.com.au/index.html Across the road from Parkmore.
328 Cheltenham Road, Keysborough
(Melways Ref: Map 89, E9)
cost of full duck is $44 extra $2 then Rock Kung, but the pieces are huge!
going there tonight cause im hungry so i'll confirm the price.
depending on where people are coming from a pre meet can be organized, but for a few its only 5mins from home, and the Shark Fin carpark is huge also.
https://www.sau.com.au/forums/topic/303253-duck-meets/
  • Replies 145
as usual... no
sorry dude, this week in hot as! hopfully friday should be cool.
i'll make a special Hamish duck meet some time :thumbsup:
Price Change, i think $44-46 is the take away price .... eat in duck is $52 for 12 pieces. i just ate 6 and im full, and there is no oil or fat on these ducks, pure moist duck pieces that are huge!
https://www.sau.com.au/forums/topic/303253-duck-meets/#findComment-5026195
can't make it... mum's birthday. shame, i like the duck there, and its so close to me too.
I might just duck in for a bit :D:)
maybe me and Hamish can do a private duck meeting.
https://www.sau.com.au/forums/topic/303253-duck-meets/#findComment-5028827
so far only 4 and a few maybe's and couple of no's.
nick msg'd me just before about a sat night meet, don't know detail's but if it still involves duck, at shark fin or rock kung, i'm down and happy to move it forward one night. If not then we'll postpone the duck meet till like a monday or tuesday so the Hamish can come to a meet :-).
I'm pretty easy and not to fussed. Obviously the majority rules when it comes to something like this :D
https://www.sau.com.au/forums/topic/303253-duck-meets/#findComment-5029106
Yeah prefer saturday, already was planning one
meet will be at rock kung or china bar, people can decide where they wana go on the night (for the service/food/cheapness they like lol)
then we can hit pool or cruise afterwoods...... maybe pics at docklands or whatever
https://www.sau.com.au/forums/topic/303253-duck-meets/#findComment-5029425
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
