HEY GUYS! CEF IS HAVING SOME TROUBLES. BASICALLY CAR RUNS FINE WHEN I START IT UP N I CAN DRIVE IT FINE FOR ABOUT 10 MINS, N THEN IT STARTS MISSING (RUNNING 5 CYLINDERS) I CHECK ALL SPARK PLUGS, AND CLEAND THEM. RAN IT AGAIN AND SAME THING HAPPENED. ALSO THERE IS A WEIRD NOISE COMING FROM THE PLENUM/INJECTORS. NEED HELP COZ ITS REALLY ANNOYING.
https://www.sau.com.au/forums/topic/303259-car-missfiring/
My Ceffy did similar and i just replaced the spark plugs and gaped them down to .8mm and the problem went away. Try new plugs they only cost about $4.50 each so try that first. If it does it at idle though its a good chance that its a coil pack.
https://www.sau.com.au/forums/topic/303259-car-missfiring/#findComment-5026271
Hahaha.... I was using my phone and it like to use capitals on posts on the net! (knew i would got a capital comment)
Yeah but they r really only new plugs though! Ill check the gapping again (sooo much fun in this weather)
And yeah once it starts missing (so far i noticed either till the engine warms up or 10-15 mins of driving) it does it on idle and on acceleration, doesnt sound it on deceleration
Sounds like its got a lumpy cam or a wrx!
And if its a coil pack normally would one just go or the lot, and the fun part how do u find the faulty coil pack?
https://www.sau.com.au/forums/topic/303259-car-missfiring/#findComment-5026557
Usually one can go on its own. If its missing on idle you just unclip a coil pack 1 at a time. If it makes it worse then you know you have uncliped a good one. If it stays the same you have unpluged the stuffed one. If one is stuffed you might as well replace them all as they will all start to fail from old age.
https://www.sau.com.au/forums/topic/303259-car-missfiring/#findComment-5026626
Cheers guys!
Might do some tests on the coil packs!
The only thing i dont get is, It runs fine when i first start her up run perfectally then all of a sudden it starts missing once engine is at running temp or 10 mins of driving!
I wouldnt be so confused if it did it all the time, constatally missfired... But it doesnt! Any ideas on that as well?
https://www.sau.com.au/forums/topic/303259-car-missfiring/#findComment-5026759
Cheers guys!
It would be the coilpacks getting hot and shorting out would be my guess.
https://www.sau.com.au/forums/topic/303259-car-missfiring/#findComment-5026770
Hmmm... And i never thought of that! (my excuse... Iv got heat stroke LOL)
If thats the case how could i resove it if its goin to heat up no matter what???
https://www.sau.com.au/forums/topic/303259-car-missfiring/#findComment-5026775
Silicone sounds good right about now... Only coz i cant be fu(ked!
Well hopefully i got more $$$ my way soon... Will be handy!
Thinking of silicone as i will be doin a 30/25det conversion.... hopefully soon!
https://www.sau.com.au/forums/topic/303259-car-missfiring/#findComment-5026787
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
