  • Replies 107
lol 300rwkw and a heavy right foot has its drawbacks :D
i get 220km to 3/4 tank, so i'd say 300 to a tank
lol terrible... i have about the same power as you and last tank got 420km.
Before the tune it was doing about 500km per tank, so extra 100kw in the tune and only lost 80km per tank, pretty good.
Averaging 13L/100km over the last 20000kms, track days excluded from calculation.
Babying it day to day though. I can get about 420km per tank before the light comes on. I'm trying my heart out to hit the 500km mark in daily driving without the help of going on long trips via the highway.
Used to get 14-15/100km when I first got the car and it was completely stock except for cat back exhaust. Have to admit that I was in new toy mode though.
Edited by UnCo
yeah mine fails hard cause of stop start driving and the cold start being on for like 50% of the time :D
at my old house it was about the same as yours... and on cruises i get the same as most people with similar power
I get about 400-450 stop start driving.. 500-550 on long trips
cruising around the trip shows around 12L/100KM and cruising on the freeway gets down to about 10 L/100KM
Not to bad for an old RB30E manual :D
Yea... you'd want to get that tune if you're driving a lot. Hahaha. I got 450-500 per tank easy before the tune and after its still 450. But having said that, if I feel like letting it loose a little, it'll drop to 350-400. Still good consumption imo.
Usually between 12.5 to 14.5L/100km
Mods are:
3" turbo back exhuast with high flow CAT
POD
R34 GTT SMIC
Bleed valve set at 10PSI
SAFC-2
Made ~180rwkw when I got it tuned.
Maybe everyone should post up L/100km or km/L instead of full tank. Better way of comparison.
Agreed. Tank is pretty useless because everyone fills up at a different point.
I think going by full tank might be a better representative of the car's overall fuel economy since it will weigh differently when full,1/2 or 1/4 empty.
I am much happier with the consumption I'm getting considering its a GTR though I do miss 500-600km that I got from NA cars.
Nah, not when the term full tank can mean 50 litres or 55 litres!
Best thing to do is fill a tank until full (petrol pump click), reset the trip meter to zero...when the tank is near empty again go fill up at the servo and take note of how many litres it took to fill. Then divide your litres by your km traveled and multiply by 100 for a litres/100km figure.
340awkw i get 200km/tank flat.. no boost..
Shouldnt the car run like a normal car when its not on boost (consumption wise)? That sucks. And thats at 340awkw... I'm curious whats the consumption like for those 1000hp cars... hahaha.
That's what I mean.
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
