340awkw i get 200km/tank flat.. no boost..
Dude I thought my car was bad. I can understand if you're on constant boost. Are you sure all the usual culprits have been tested? O2 sensor, oil filter, injectors, fuel filter, AFR, you're not leaving the handbrake on :(?
I'm curious whats the consumption like for those 1000hp cars... hahaha.
There's a reason those cars need 200L/hr fuel pumps :cool:
  • Replies 107
Dude I thought my car was bad. I can understand if you're on constant boost. Are you sure all the usual culprits have been tested? O2 sensor, oil filter, injectors, fuel filter, AFR, you're not leaving the handbrake on :banana: ?
There's a reason those cars need 200L/hr fuel pumps :D
lol everythin is workin fine.. its partially my choice.. lol told the tuner no compromise.. haha but its city driving tho.. not highway :) only part i sacrifices was top end power for mid range :banana:
18L/100km... thats shit! But I suppose if you're running high hp, you can justify that.
lol terrible... i have about the same power as you and last tank got 420km.
Before the tune it was doing about 500km per tank, so extra 100kw in the tune and only lost 80km per tank, pretty good.
:banana:
280rwkw here, 450-500 CBD style driving, 600-650 freeway. I don't expect that to change with 330rwkw, because if you are just crusing around power output should make zero difference.
My fuel filler cap literally leaks when going around tight corners, so im probably losing a litre or two each tankas well (i can see it pouring out lol).
So I could probably get more if i wanted... I'll be doing a Syd run in Feb/Mar so ill find out exactly what i can do provided i don't get to excited on the way up hehe
Oh, and im not using O2 sensors either.
lol everythin is workin fine.. its partially my choice.. lol told the tuner no compromise.. haha but its city driving tho.. not highway :banana: only part i sacrifices was top end power for mid range :banana:
Big difference between no compromise tune and one that is just crap.
And honestly, you can have perfectly good power level/response and reasonable economy @ the same time.
200km's is 50 1/4. Fk that... You win the worst tune award - i'd be taking it back.
  • 7 months later...
Something must be wrong then with my 33.
its even a sedan and its only reaching 360 a tank.. and its stock like a rock. ive had the o2 sesonsor and everything checked i still can not find a reason to why it would be doing this...
ive got an r34 gtr and think the fuel consumption isnt that bad, i dont have exact figures because i tend to fill up whenever i feel like so sometimes when i have a quarter of a tank or other times a little less. it seems to only use a little bit more than my old r34 gtt. and i know the fuel consumption can definately be better it runs very rich. id say i would get roughly from just adding up the km in my head and from when i filled it up till now because ive only been to work and back plus this is in stop start traffic ive traveled roughly 300-350km and still have a quarter of a tank left.
ps. thats still giving it a squirt here and there.
Doesnt matter mate. Just reset your meter when you fill up and note how much you travel and top up the next time. You'll be able to work out a L/100km or km/L consumption easily.
A tank consumption isnt always accurate because you dont know how much L you've used, unless you run it till it stop.
finally got figures for my r34 gtr, driving was a mixture of everything: stop start traffic, freeway and of course giving it a squirt here and there. all it has is a catback exhaust and my average is 14.1L/100km, if i kept going i could of easily gone 400km to a tank.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
