Hey everyone!
Texi is on Jan 31st, and like always we need helpers on the day to do things like timing, end gates, "3 2 1 GO!", marshalling etc - basically all the things you saw myself and the legends who helped out last time doing
None of the jobs are hard at all, its an easy way to get up close to the action.
A couple of people have already offered to help out, who did so without knowing there would be payment; What legends! (and yes, they'll be paid now)
I do need helpers onsite from 830am until event ends which should be 445pm. There will be a lunch break around 1230pm while the courses are changed to the afternoon courses
Lunch and drinks will be provided free throughout the day.
Yes you can choose what job to do, here's each one;
- "3 2 1, GO!"
Counting down the time so drivers know when to start their runs. Very simple, just need a loud voice and 3 fingers to hold up
- "Timer"
Timing each run and writing down the end time on a form provided. Also if someone goes a wrong direction or hits a cone, taking note of that.
- "Marshall"
Ensuring the flow of cars onto and off the track stays smooth. Its basically a traffic controller job, making sure the entry to the skidpan (single lane) doesnt have a traffic jam and that the next car is ready to have their run. Common sense really!
- "End gate"
An official who mans the end gate of a course, reports if an entrant hit a cone, and once the entrant has come to a complete stop will move a single cone out of the way for the entrant to move to next course
I need;
2xtimers
1xmarshall
1xend gate
1x3 2 1 GO
So far the following have offered (sorry if someone offered and i missed it);
MsNismo (Timing)
Xmetal
BezerkR32
So we need a few more - who can help out and earn some coin for the day? :(
https://www.sau.com.au/forums/topic/303402-help-needed-50-per-person/
If my car breaks on Thursday I'll scream 3 - 2 - 1 - Go, or traffic control and even if it doesn't break, gimme a job as I said to you a few weeks ago in PM.
Uncy Duncs and all the others managed to get runs in last time, so I'm pretty sure I can manage to if you gimme a job,
i was going to bring my camera up hoping that you might be able to learn me some stuff.....
I'm always up for it Steve. I can hand my camera to someone else for a while if you need another set of hands. :banana:
hmm seems there's enough people willing to volunteer
I'm not fussed either way, just if needed I'm happy to free up a spot for someone who wants in if it gets full & then be a marshall
If not I'll just have to show these skirts how to texi :P
hey ill be more then happy to do anything on the day for the club, not sure as to how much help i would be but if i can run a store im sure i can time or countdown or do little jobs for you guys! as long as i get to see some skylines!
For sure! I don't mind doing tutoring on the day. :huh:
Eric! I'm wanting to have a go at motion picture too so yeah i'll do some footage time as well. ;)
I would have thought more peeps would take up Steve-o's offer of 50 buck each,,,hell I'm thinking about it and with back pay I'll be owed about $2000.
Are you paying us cash mate or are you using your cheque book?.
Everybody Steve-o's not really going to pay you 50 smackers,,,he's just a funny bastard.
Neil.
Well, Pay or not I'm still in for 1/2 day. With all of the work that goes into an event such as this we really do need our members to step up and help out from time to time on the event.
I think Xmetal has the same outlook but check with him then assign me a job.
See ya there - oh, I've got a new tiny camera that is the size of a key fob - great for really low on-board or in cabin shot back at the driver.
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
