More sleep, less alco will fix the eyes :banana:
How did you fail last time? What grade sandpaper did you use? What did you do after you sanded to finish the job?
Ive never sanded mine. Just used an old T shirt/ singlet and get good results out of whatever brand polish I have in the shed at the time. Goes from a lightish color with yellow tinge. When finished the headlights look much darker. Only takes 2-3 minutes per side. Repeat roughly every couple of months. I did try meguiars metal polish once but found that just a general general brand polish did just as gooda job.
Edited by l_uk3y
I bought a kit off eBay - little bit of sanding involved but they give you the correct sandpaper. Think it was called glassylite or something like that. Cost me about $30. Headlights look pretty good now.
I stopped at a Bursons store yesterday and noticed they had the same sort of thing for about $50
Likewise. Glassylite kit is the best stuff...comes with sandpaper, cleaner, polish and nano-sealant. Mine are still clear as daylight and it's been about 2 months since I used the Glasslite.
20 months on and mine are clear as. Why not use a SAU Vic supporter in Final Inspection? Get the car detailed, headlights done at the same time and you're good to go.
I still recommend to people, paint polish and a MACHINE, not a 'hand job' will give you the results you really want. Some headlights do require a wetsand if really bad, but most times, you can just attack with paint polish and a machine. Keep them waxed and you shouldn't have an issue for a long time IF corrected properly in the first place.
If the FI gallery wasn't down, i'd show you what can be done with paint polish and a machine ... Damian took some great shots...
SS8, whats a machine..? im not following when you say polish and a machine...
anyway im gonna try again to scub them out a bit this afternoon when it cools down, cause SHIT its hot today... not as bad as yesterday but still >.<!
i might just try toothpaste first ^_^
he means polish it using a machine
i did the lights on my R34. only did a half assed job cause i was just seeing how it comes out and it came out good.
got myself some mild rubbing compount and gave the geadlights a good rub. the grains int he cutting compount cut away 90% of the yellow tinge but after a quick wipe it left the headlight dull. then got some paint polish and rubbed it on the headlight. using a buffer (machine) i buffed the headligth then put a coat or carnuba (sp) wax on it. and its come out awesome. all up each headlight took me 20mins
depending on where your located i can come and do yours for you.
wahhhh
if ur Serious about it ashneel ill take u up on that, im in wheelers hill like 10min away max..
anyway pm'd u
kitten plastic polish and a terry towel. takes a few applications and will fix them right up. Take you 5 minutes. May have to do it every couple of months or so depending. Dont bother with the whole sandpaper bullshit, whole lot of work for no reason
use AUTOSOL metal polish from supercheap auto , any other plastic polish is ok but this kicks ass
pretty sure theres a reason its metal polish and plastic polish
just taking a guess and saying different chemicals in each and could damage if used on wrong application
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
