  • Replies 846
Posted Images
If it is my turn in line - I guess I'll say yep.
:( will be there to see this thing in action again.... last time i saw this on the track it was like a limping t rex.... an animal pulling 1:14-1:16! but ive heard alot ahs changed!
Is it wrong for me to want 4 people to drop out so that I can see, hear and compare with Blue32's R32 GTR? :D
Jugs had to pull out of this event, just got the news now. Dohmar, you're up
EDIT: Dohmar said no, Blue32 is up
*sings*
"When you wish upon a starrrr,
Makes no difference who you arrrrrre" :banana:
hahaha itching to get on the track David
Definitely.
Considering going to the open day at Mallala on the 27th.
But I'm still dirty at Santa for not giving me a big brake upgrade kit. If only I could find $10k laying around.
Definitely.
arent we all.....i am trying to get everything sorted out before i fly to fiji at the end of march.....one month to do almost everything uummmm.....dont worry i will be back from fiji in time to have the 33 on the track.....
needs zorst, clutch, braided brake lines, servicing, diff
just need time and money
looking forward to this too!!
got some a1rm's fronts on the way, new swirl pot and pumps hopefully setup too, will be setting a lowish boost level and try do my best to stay out the way of you test pilots.
and he seemed so gung ho about it. what changed? oh well, for the better i spose, lookin forward to seeing more of blue32's impromptu barbecues! :D
Definitely.
yeah I recon lines have enough power and handling capabilities for the "Dustbowl" but braking is definitely an area that the Porsches have over us.
What?? I'm cooking the bbq?? :)
Ahhhhhh, thanks for offering Andrew :rofl:
not having a job at the moment is a killer.
-D
That's fine mate and completely understandable.....maybe next time. :)
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
