  • Replies 846
Posted Images
think i have fixed my split turbo oil line. Will soon find out!
car is packed, and Adrian and I are both very excited!
will see you guys at the Caltex BP* :)
So i am guessing the name has been changed from caltex to bp......just gotta take a few things out of the car and the car is officially ready for the track...drives fine and has been driven all day today.....also luke dont forget my jerry with bp ultimate and a bottle of octane booster :P
Man, you guys are keen. I will roll out there around 8.30 ish as from past experience
there is nothing much happening before 9am. ( & I really need my sleep!)
My brother is bringing my Race GTR out around 10 so will have a go with the R35 first
to get into the groove. Hope its not too windy......
See you all there.
haha, me and krish were belting out some mad flames. awesome.
f**kin stoked with how my car performed today, everything felt a bit alien in the start, new alignment settings all over the place, and working brakes (ha!), so i was a bit sketchy the first couple sessions.
but yeah, smashed out a 1:27 dead. i lost my shit when i saw that, fist out the window and everything. its a shame ill be advertising her for sale in the next couple days. bit more power and theres a 25 in there somewhere.
and thanks to ruby for a couple pointers for tackling turn 1.
and a big congratulations to munro for cracking into the 12's! f**king incredible effort mate!
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
