Ive recently learned that Mercury Motorsport has been appointed the official QLD distributor for CSR E85. Trent informed me during a brief chat at the track the other day he has scored the ditribution rights for this fuel in QLD. This is exactly the same fuel as is being currenlty used by AVESCO in the V8 supercar series. Trent is about to recieve the first delivery of the new fuel and is keen to show some back to back tests against not only regular unleaded but also some of the more expensive race fuels.
Im keen to see some results.
Also very keen on this! I've had to use E85 ELF Branded 200L drums and it's not cheap - $2.50 litre + freight (200L drum) - the 20L are even dearer.
What mix are they using for the other 15% - 98 RON? or lower
Seriously considering changing to a meth mix but not sure how the 2x 044's would handle the highly toxic mix. (Posted a thread in FI Performance)
Edited by Parag0n
from what ive been told methanol and electric driven fuel pumps are a no-no.
Ive witnessed first hand how well this fuel performs and how much safer it is for your tuned motor. At $2-3/Lt, its a bargain compared to fuel like VP109 and even C16.
GT-Auto Garage have been using it in a few of the hi powered gtr and fd's with amazing results.....
smells awesome out the tail pipe too :D
Just as I stumbled across this thread, our first 4 drums of E85 are being unloaded!!!
We have also been using it at our workshop on client's cars. We made 924hp on 33psi using E85 on an R34 GTR just last week! We also have a number of cars that have cracked the 500+rwhp using E85, including an EVO 8 that made 588hp at all 4 on a standard bottom end!! The ignition timing gains and safety when running more boost are truly amazing for a fuel that is only $2.50/L.
dropping that in yours would make it a ballistic ride.. (when do we go for a run again :D )
Good on you for getting it in Mercury but it really burns my arse knowing that the guys down south are paying just over a buck a litre for it at the bowser while the only way we can get it is via 200 litre drums.
They make the shit in qld FFS!
Yeah whats with that . . . F*ckin Mexicans
sounds like it's time for a road trip in the patrol :D
Is it 108 octane at the bowser? I thought it was only 98 octane e85 available on pump?
The CSR E85 is the top of the line fuel. As far as I know, there is no equivalent available. It has anti-corrosion additives to ensure your fuel system doesn't melt from the inside out and to ensure it can be used/stored long term.
For us, its peace of mind that it is the same strength each and every drum (wont lose octane or have octane variation from drum to drum) and it also won't separate whilst being stored. These two issues were my biggest concern in the past when we used to mix up our own "home brew" E85, but using the CSR E85 is far superior.
Nah, Down south they already have the 108 octane bud. it farken stinks.
There are several threads on it in the forced induction section.
Still need answered what the other 15% is
I would imagine it would be 98 octane eg BP
Ok, well check them out.
I can confirm 108 octane at the pump...
I travel all the time, see it everywhere... Put some in a rental camry I had :)
Good old rentals! they get all the royal treatment!
How long term are we talking that it can be stored?
I have been told it will store for 100+years in a sealed environment without settling out. Basically the only way to separate the components would be to distill it again.
Trent how much are you charging per ltr? Is it available only by the drum? Very interested in how things go with this. Are you charging the same price per hour for an E85 tune as for a 'normal' tune?
www.fuelcontrol.com.au mentions the mix for CSR E85 is 15% premium. I'll presume that is 95ron?
Anyone care to post the spec sheets etc? Pretty interested in the anti-corrosion stuff...
Cheers
Michael
Cheers
Michael
Yes I need a definitive answer on the other 15% as I have a map on my Motec M400 tuned specifically for ELF branded E85 which is 15% 98 octane, everytime, doesn't differ per barrel.
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
