Hi all,
I'm over in the Uk, haven't been on the site for a little while but i'm hoping that some of you guys can help me out as you have alot more knowledge with N/A Skyline's than us lot!
I've got a '96 R33 GTS with the RB25DE.
I've just completed having individual throttle bodies fitted and mapped up etc.
Current tuning mods are:
Emerald K3 ECU
Custom made throttle body set up using GTR throttle bodies, Jenvey trumpets and Piper X filter socks
Uprated coilpacks
Wasted spark set up
Coby D12 exhaust manifold
Custom Powerflow 2.5in exhaust system
Tomei adjustable cam gears (only the exhaust one fitted atm where NVCS has been removed)
A/C removed
The car's acheieved 201bhp at the flywheel and now rev's up over 7500RPM.
Power delivery, torque and fueling have all smoothed out.
We're now looking to extract some more power.
There's a shift function on the ECU which means the other adjustable cam can be fitted and should she another 30-40bhp.
We're looking at doing something with the cam's next.
Does anyone do aftermarket cam's for the N/A?
If not, can the standard cam's be reprofiled to be more efficent?
If so, what's the best profile?
Any other info on cams or anything else i can do to futher extract more power will be greatly appreciated.
Here's a pic (sorry pic quality ain't great) of the set up so far!
https://www.sau.com.au/forums/topic/304833-need-your-help-cams/
Hi all,
Emerald K3 ECU
Uprated coilpacks
Wasted spark set up
A/C removed
you can regrind your cams to get more lift but duration is not so easy becareful revving it to 7500rpm the hydraulic tappets don't like it
this is how an NA RB should be done :D
Most after market cams are to suit turbo cars
so head over to camshaftshop.com and get kelford to make you up some big bastards to suit the NA throw in some better valve springs and if you can afford it a solid lifter coversion (just make sure that if you do the solid conversion that you get cams to suit)
Next step rev that bad boy to 9000+
Cheers all for the good comments!
I'll get a vid up soon and some better pics, picking her up next week as it cost me a lil bit more than i expected! lol!
She drives soooooo smooth tho and the sound! ;)
Hesh! send me a tx mate, i lost your number when my phone got repaired, they wiped the bloody memory! :)
Thanks for the info on the cams and cheers zebra, i'll check the site out!
I'm running ITB's on an RB20DE in my rallycar. Still a 2ltr for class requirements.
I don't have the exact spec of the cam's on hand, but they are 280° duration and max lift we could run with the standard lifters/followers. The head has also had a lot of porting done, although I feel we may have gone a little too far on the port size and cams. It pulls strong for a 2ltr, but is very fussy on intake length adjustment and doesn't have the torque I'm looking for yet.
Cams are a custom grind made by Kelford Cams, as no one really has any spec's on ITB N/A RB motors. I would say the 2.5ltr will be easier to strike the right tune with the cams thanks to the extra capacity. To me it sounds like you are after peak hp and rpm? I'm after the opposite, however the 'lil bugger does like to rev to 8,500rpm all day long on the stock bottom end. Oh and the sound!! :P
Vids' FYI
-motor is too flat below 4,000rpm
Edited by screamin'
Cams are a custom grind made by Kelford Cams, as no one really has any spec's on ITB N/A RB motors. I would say the 2.5ltr will be easier to strike the right tune with the cams thanks to the extra capacity. To me it sounds like you are after peak hp and rpm? I'm after the opposite, however the 'lil bugger does like to rev to 8,500rpm all day long on the stock bottom end. Oh and the sound!! :thumbsup:
Vids' FYI
I'm after swinging to 8500 RPM but on a 3L...
Also, people say it's "in the lift and duration" how? do they lift less but have an uber long duration or something? I want to know that if you ran a 256degree Turbo cam, what the difference is to a 256 NA cam...
Cams are a custom grind made by Kelford Cams, as no one really has any spec's on ITB N/A RB motors. I would say the 2.5ltr will be easier to strike the right tune with the cams thanks to the extra capacity. To me it sounds like you are after peak hp and rpm? I'm after the opposite, however the 'lil bugger does like to rev to 8,500rpm all day long on the stock bottom end. Oh and the sound!! :)
Vids' FYI
Sweet mate!
I'm a torque hunter like yourself bud :)
I wouldn't mind upping the hp abit tho, 300bhp would be nice.
The car's going in again in 2 weeks for a shift light function wiring in that can be used with the K3.
It should hopefully see some more hp, the garage has said possibly between 30 - 45bhp depending on how much they can fine tune it which they are fairly confident in.
Here's a vid of how she sound's!
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
