Hi Guys,
Just thought I would link you to my car on the dyno at Hyperdrive.
Just wanted to say thanks to Oz and Cem for all the hard work they have put into my car.
Also thanks to Andrew at Hyperdrive for doing such a great job on the tune and looking after me.
Also what oil cooler kit would you recommend me buying and from where?
I would like one before I do a track day.....! :D
Cheers,
Ken
https://www.sau.com.au/forums/topic/304856-dyno-hyperdrive/
Well done man, that thing is beasty!
What plans have you got for it in the future?
Thanks Martin!
Not sure but I only wanted 350 out if it at the start but I got 400 so im happy (at the moment) haha....
I will take it to the drags soon and im thinking of joining SAUWA but I don't seem to find the time to even hit the drags :D
https://www.sau.com.au/forums/topic/304856-dyno-hyperdrive/#findComment-5046961
Nice one mate :) Love that thing, really do, you've put so much work into it, has to be the cleanest R34 I have seen in a LONG time.
Now get your mate to buy my GTR.......... ;)
Thanks Chris :D
No your keeping the gtr, its mint!
How dare you try to sell it haha :)
https://www.sau.com.au/forums/topic/304856-dyno-hyperdrive/#findComment-5047241
Nice. Hyperdrive do great work and Andy is a champ.
Is yours external or internal and is it 0.82?
You got to love the gt3076r i couldnt be happpiers with mine. I just wish i had a 3litre
Edited by Pattygtst
https://www.sau.com.au/forums/topic/304856-dyno-hyperdrive/#findComment-5047433
That's a sweet achievement mate, especially on Hyperdrives roller.
Thanks Clint, yeah hyperdrives dyno is harsh...
I was thinking of going All Star for a power run on the Hubs and getting a better looking dyno graph...
But thats being a hp fan boy haha ;)
Mine is internal but im using cams with 17psi from a GT3076 so it works well.
I went for internal to keep it street friendly :)
https://www.sau.com.au/forums/topic/304856-dyno-hyperdrive/#findComment-5047461
I went for internal to keep it street friendly :rofl2:
I have same turbo but external gate for my 34 sedan, also have tomei cams , greddy plenum , 6 boost with 50mm trust gate .. Andy will tune it once i done all the fab work
Hey just as a matter of interest, whats this thing like on petrol?
LOL choose 1 .. power or fuel economy :domokun:
https://www.sau.com.au/forums/topic/304856-dyno-hyperdrive/#findComment-5049033
Its actually not to bad.. but it really depends how you drive.
When I just had the basic bolt on mods with a tune I was pulling 400-410 on full tank (BP Ultimate 98).
Right now I average about 370-380 on a full tank but like I said really depends how you drive the car :domokun:
Nice, with the external gate you will be able to boost it much harder.. Engine Stock internals? Just the cams done?
Also I would like a greddy plenum, that is my next engine mod... Makes the engine bay look like SEX :rofl2:
Edited by KEN-R34
https://www.sau.com.au/forums/topic/304856-dyno-hyperdrive/#findComment-5049065
Lol yeh i know its not going to be efficient, i just wanted to know how much he gets to a tank driving like he usually does.
Just to be the devils advocate, i know of a certain eco car that does 0-60 in 2.5 seconds. The Shelby Ultimate Aero EV has 1000hp, 800lb-ft of torque, and gets 400-500kms out of a charge. Absolutely no petrol involved :rofl2:
https://www.sau.com.au/forums/topic/304856-dyno-hyperdrive/#findComment-5049074
Also I would like a greddy plenum, that is my next engine mod... Makes the engine bay look like SEX :domokun:
Im only after 400 . Neo in my 31 has greddy plenum on it , from throttle body to cooler the pipe is 300ish long :rofl2:
https://www.sau.com.au/forums/topic/304856-dyno-hyperdrive/#findComment-5049168
The 'Fuel Economy & Hippies' forum is that way..
lol...
Im only after 400 . Neo in my 31 has greddy plenum on it , from throttle body to cooler the pipe is 300ish long :P
You will make 400 easy on your 34.
Going for 400+ RB25 with stock internals is a bit risky but then again depends how you drive it.
Your 34 is a track car right? Your going to give it a good thrash most of the time :(
How man ks has your neo done?
I would like to know how long your engine lasts with 400 usage on the track.
Don't mean that in a bad way at all.... could last a very long time who knows.
https://www.sau.com.au/forums/topic/304856-dyno-hyperdrive/#findComment-5049293
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
