Heading out the door in 5 ... once I cool the pour staffy down.
Funny ... my house is a double brick 1960s house and the original aircon in the wall (cavemen built it) is still running perfectly fine. :P
or change the title :P
Or that lol. Anyone heading to Vilis Friday? I'm most likely going to be there and wave goodbye to the peoples going to the land of Japs.
It is the begining of the week, ask again closer to the date...also it depends if the people going to the "Land of Japs" decide to go to Vilis...I may as I am not working that night...you could wave goodbye to some of them at the SAUSA Cruise this weekend.
I refuse to return that wave.
Might come to Vili's, depends on work and care factor on the night.
Who says it would have to be a wave...whats not to say it's a "full-hearty hug" :P
Who says it would be a have...whats not to say it's a "full-hearty hug" :P
Only for you Abe hehe, I'll just give you a have instead. Nah vuvuzela, only Skylines :)
Should be there, last villis for awhile :)
Yeah same here, going to start putting even more money away so i can get my 32 in about 7-8 months (fingers crossed)
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
