i know its a silly question coming from a skyline driver like myself...but DAM!! skyline are fuel munchers arent they? anywayz..Is there any tips on how to save fuel? while driving?? maybe its gotta do on how u drive it? lol.. feel free to post
https://www.sau.com.au/forums/topic/305219-how-to-save-fuel/
^^^ correct + state of tune.
And don't forget our dear Rooster friend, living in Sydney where there's stop-start traffic, it's such a pain on the pocket to get around.
Sydney half the time is gridlock - not just at peak hour.
Do you have a daily for city travelling? If not... well you know the rest of the story...
PM-R33 is in Townsville.
My car runs around the Blue Mtns.
My mod collection is not huge, but with a well-tuned HKS F-Con Pro-V ECU I get 450Km/tank quite easily incl. occasional squirts thru the hairpins.
Soft right foot, don't hit hard of the lights, drive like somethings about to break.
Around Surfers I get 450-500 a tank with the odd get me outa here squirt, more if I do some highway, shit loads less if I boot it everywhere.
get an apexi avcr or a data display thing and drive it to the injector pulse the lower the better . has made a difference to mine . just interesting driving up a hill and wondering if what used more gas
5th gear 0 on boost gauge 2500 rpm =8% duty cycle
4th gear -250 on boost gauge 3000 rpm =10% duty cycle
5 things to use as little fuel as possible;
* Use the highest gear the engine will pull without lugging, and get into it as soon as possible
* Use the smallest possible throttle opening you (and other traffic) can stand for acceleration, and as few revs as possible
* On the open road, do all that you can to conserve momentum. Never let yourself speed up and slow down constantly.
* Cars use the least L/km the slower they are driven. Even more reason to stick to the speed limit.
* Replace your air filter before it gets cruddy, to maximise engine efficiency
And if you really want to save on fuel costs, get the car converted to run on liquid LPG injection
5 things to use as much fuel as possible, after all you DID buy a skyline, not a blouse...
* smash the loud pedal
And if you really want to save on fuel costs, you are ghey and should buy a prius like joeyjoeetcetcetc said
fixed
* Use the highest gear the engine will pull without lugging, and get into it as soon as possible Correct
* Use the smallest possible throttle opening you (and other traffic) can stand for acceleration, Not strictly cotrrect. A throttled engine is less efficient than a non-throttled engine. Big throttle opening at low revs is more efficient than smaller throttle openings at higher revs to give the same power. and as few revs as possible
* Cars use the least L/km the slower they are driven. Even more reason to stick to the speed limit. Again, not strictly correct. The most efficient will be the slowest the car can comfortably travel in top gear. The wind resistance only starts to have a big effect over about 60km/h
Most important factor and I can't believe nobody has mentioned it - avoid using brakes unless absolutely necessary. On the surface it sounds silly, but when you think about it, by the time you apply the brakes, you've already used too much fuel to get up to the speed that you need to use brakes. If you modify your driving style and think ahead, it's surprising how little you need to use the brakes. this means you're using far less power to get up to speeds where you need to apply brakes. No, it doesn't mean driving everywhere at 20km/h, either.
Also, if you think that knocking it into neutral to coast down hills is saving fuel, think again. Modern EFI systems shut off fuel altogether with 0 throttle and revs over a certain RPM (usually something llike 1800). If you coast in neutral, then the engine is being fed fuel just to keep it running, whereas if you're in gear, then the fuel system shuts down completely.
Follow some of these techniques and you can save a reasonable a mount of fuel. Just because you want to drive a Skyline doesn't mean you have to drive it like a dickhead all the time
new oxygen sensor - ask for one for an n14 sss pulsar (sr20) has the same plug as a 33 too so no cutting
get an ecutalk display too - i got one for my stag, plugs into the consult port and once you input the injector size it will do instant fuel consumption, read off every sensor the ecu has and do lost of things
www.ecutalk.com
Ride a bike. No, not because you drive the car less, so you lose weight and have less to push around. Of course, that's not going to have a huge effect.
Optimum speed is probably going to be 60-80km/h
If your weight is around 200-300kgs it might!~
www.ecutalk.com
Hmmmm i mite get that...so what exactly does the ecu does again?
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
