  • Replies 58
You can reply in the fast reply box, but you can't use the full editor.
Like if you quote some one and you get to this screen....
There is no cursor in the text box and you can't click in it to type..
also if you use the full editor, you get the same problem.. but the quick edit is fine.
Must be the dark one?
I honestly have no issues with any FF versions 3.6 or 3.62, i update soon as they are ready.
I'm using light skin only.
I have heaps of add-on's as well (adblock, site location and others)
You running windows nismoid?
Indeed - Windows 7
FF3.62 upgrade seems to have fixed the issues I had with the refreshing of pages after posting.
See i was never getting that issue either.
If i did a quick edit - and saved it, it would update my post immediately without me having to belt F5
Nismoid maybe it has something to be with you having an admin account. Could you try making a new account or using someone elses and see what happens?
I have to use IE ( hurt to say that ) to post in here. I can't with fire fox. :)
I'm an admin and I've got the issue showing up intermittently now, so we can rule that out.
It happens on my machine at work (was running FF 3.6, but running FF 3.6.2 now), but doesn't happen on my machine at home (running FF 3.6 and 3.6.2 since last night). Really has me stumped... :)
It happens on my machine at work (was running FF 3.6, but running FF 3.6.2 now), but doesn't happen on my machine at home (running FF 3.6 and 3.6.2 since last night). Really has me stumped... :blink:
Dif'rent OS?
i'm running FF 3.62, and previously 3.6, on win 7 and havent seen any of these issues at all.
in fact, control panel, find members posts, etc, seem to load faster than ever before. prob due to the new local hosting.
ive noticed PMs and posting in a thread (like now) takes quite a while to send (<1 min). but surely thats not browser related.
Edited by Munkyb0y
Still got issues with posting new threads in FF 3.6.3. add ons enabled or disabled doesn't matter. No cursor in text box. Works fine in fast reply and quick edit but nothing else. WIN 7 Ultimate 32bit. Pain in the arse really. have we got a fix for this yet? It only happens on this forum none of the others I use have it but they are also not Invision boards.
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
