RB25DET Neo Vs RB25/30
47 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 45
I used to run a built RB25 in my HQ (auto box) making 280ish rwkw @ 20psi. It was very fast once on boost (GT3082R) but it was still relatively laggy with this turbo. I then built a RB30 bottom end and matched it to the same turbo, the car made more power @ 18psi and 1000ish RPM earlier. It was the best decision I ever made and I absolutely regret wasting my money on building the original RB25. The 30 is just so much smoother and nicer to drive. So much power and torque down low and it just pulls and pulls and pulls. If I could do it all again, I would go straight to an RB30 bottom end... Especially on a street car when low RPM cruising is essential. I'm now running a GT3540 and it still makes boost earlier than the 25 with small turbo and its a billion times better to drive. Thats my experience :P
How about all those Supras, RX7's and Big V8's running 800rw/hp with 9-10sec passes that are all RWD?
I think it comes down to decent suspension, tyre setup and launch control.
From what I have read, the RB25/30 will be a great street/drag combo however just waiting to take a drive in Dave's car to see how the new RB25 + turbo setup goes :worship:
Edited by QRI05E
Hmmm I await your impressions QRI05E, I'm in the same boat as ya, got a r33 gtst s2 bone stock (engine wise) and looking for idea's xD. alas the age old debate, rb25 or rb30/25....plus being in nrth qld limits my engine builders down a bit.
any suggestions onto who does 'mail in' engines? I'm doing research ^^;
Nothing stopping you shipping the engine/bits down to them to get it built.
Bubba, missed that post will pm you some.
Spoke to Adam my tuner today and here is what we have decided.
Stock RB25DET Neo
- High mount twin scroll manifold
- Garrett GT35R with .82 rear
- Bosch 040
- 800cc injectors
- SARD FPR
- FMIC
- Greddy Plenum
- Q45 Throttle
- Full exhaust
- Haltech E11v2
Should see easily 300rw/kw
Drive around for a while... then when I need more power... RB25/30DET with the same setup should see 400rw/kw
twin scroll manifold with non twin scroll rear housing on the turbo?
i am not sure if a 040 will support 300-400kw, you may want to look into using a 044 instead.
forget the sard fuel pressure reg waste of money, 800cc injectors will outflow a GT35R @ stock fuel pressure.
Agreed.
That, and with that turbo, why not throw an RB30E in there, run less boost, make more torque and earlier, and have a much more streetable setup?
I will be throwing in the RB25/30 in there eventually... just didnt see the point of ripping out a perfectly good engine. The reason for the GT35R is to that when I do decide to build the RB25/30 I wont need to update the turbo.
Would a T04Z be overkill? Im thinking about the new Garrett GT3788R... Any ideas?
What's the resoning behind changing the throttle body exactly?
All it'll do is hard throttle control. Not like the factory unit doesn't flow enough, everyone else has made 380rwkw out of it easily enough.
From what I have seen, all the 400kw+ RB's switch to a larger throttle but we'll see how we go.
Will I run onto any issues with the RB25 Neo head on the RB30? I have read a few posts with people running into a few issues such as the bolting up a Greddy plenum with the factory thottle body.
Edited by QRI05E
Where have you seen this exactly?
Just because people change a part, does not mean it's a requirement or needed. Some people just get caught up in what they get fed.
recent thread come up about this actually!
http://www.skylinesaustralia.com/forums/La...dy-t291471.html
R31Nismoid - Thanks for the info, like I said, i might just wait and see how we go.
Anyone used a GT3788R on a RB25 yet?
If youwant streetable response, look at the GT3076 or the 3082.
When that gets thrown on the RB25/30, you'll have an unreal combination that will NOT have to be revved, but will be able to when needed.
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
