I did this set up on a R33 GTST a while ago and it improved its 1/4 time by 0.5 of a second. You would need a heap more horsepower (and cash) to get that result from the engine alone.
Sorry if I hijacked the thread there
Happy New Year to all
Ive got Tein suspension all round and the back is not too low, and i consider it to ride as hard as a rock and with my street Sumitono's HRZT i ran a best 60 footer of 1.94 with heaps of others in the 2.0 bracket. On the positive side i was running low 20psi in the tyres and getting plenty of heat into them,
Hi Robo's, you're right, getting the tyre pressures set correctly is very important. A pound or two either way makes a difference and lower pressure is better.
You can get away with stiffer rear suspension if the track is very smooth and prepared, but the road is never that smooth. There are always ripples, bumps and ridges to trip up the rear end under high power and 300 rwkw is certainly in that catagory.
The more power you have the harder it is to get the launch right as the margins between bog and wheelspin get smaller with every kw. Ohh and that GTST did a 1.68 for 60', so there is always room to go faster but the gains are smaller and much harder work.
That's enough hijacking of this thread for me.
Hi Steve, if you adjust the camber using top and bottom, inner and outer offset bushes, you don't get a lot of camber change. You can set up a drag car so that it stays pretty much 0 camber over the range of movement. As you suggested, it starts out slightly positive and ends up slightly negative. We check this by removing the springs and jacking the chassis up and down on the wheel aligner.
We know how much the suspension compresses by using cable ties on the shock shafts. After a run we can determine how much the suspension compressed by measuring where the cable ties ended up on the shaft.
Conversely we set up the circuit race cars so that they have pre determined compensation for the body roll and tyre compression with camber change. The camber change angles over the range of suspension movement is very important, we only have 240 mm of tyre width and I like to use it all, all of the time. Due to budget we can be bit more sophisticated, we use the data logging facility on the Motec dash and a set of movement resistors to determine the range of suspension travel in each corner. So I can end up with different static camber and different rates of change on each corner of the car.
A road car would be set up somewhere in between.
So in all cases the rate of camber change is just as important (maybe even more so) as the static camber.
Oooops, that well and truly hijacked the thread, sorry...
$11k is a lot of moolah to spend on a GTS-t in stock form. My car has at least that much worth of mods on it, but I bought the car with a lot of the mods already in place.
If I a full $11k extra to start with, I would have preferred to buy a GTR. The only reason I didn't was because it was just a little too far out of my budget. At the time (1.5 years ago) the cheapest GTR was $30k. I had about $25k to spend all up including insurance and rego, so it was just too far out of my budget.
If I had the money again today, I think I could squeeze an R32 GTR into my budget ;) But now the money's been spent on the GTS-t and it's got some nice mods, and I wouldn't wanna "upgrade" to a stock GTR with it.
The 4WD of the GTR is of course an advantage, but i was amazed to see how little the torque gauge moves on R33 GTRs at the track. Even on turns 2 and 9 at Eastern Creek, and coming onto the straight at Wakefield, so the balance and handling of the GTR owes more to the basic susp config and chassis then the 4wd...
So throw in the added weight, the additional stresses of 4wd and the additional cost of GTR, and only 100cc advantage over an RB25DET, i think the R33 GTST is about the perfect platform for a well rounded performance car. (Kind of same thinking as why Porsche chose RWD for GT2 & GT3 performace flagships)
And i will aways believe that a RWD car is more fun & challenging to drive, and im not into competive motorsport so dont really care if im not the quickest car out there.
Am i right in assuming you can have a 300rwkw GTST cheaper then a 300rwkw GTR (assuming both R33s)?
It might be only a 100cc more... but the whole design and composition on the motor is totally different with the 26. That's where the bigger differences are, not the extra few cc's
but isnt the RB26 an square motor, allowing more rev's to occur ???
I know there are differences like that but im not too technical so i wont go throwing around terms i dunno how to use
internals are alos stronger too.
Yeah the basic RB bit is the same... but then, apply that to all RB motors.
but u said this just before
"It might be only a 100cc more... but the whole design and composition on the motor is totally different with the 26. That's where the bigger differences are, not the extra few cc's"
so u aint technical but the whole design and composition is different?? how do u know this if u aint so technical? :D
Bah, go stick it in your ass Denham, you know what i mean. :upurs:
I said in my other post
now. stop using this thread as an excuse to get your jollies over stirrung me up (again :rofl)
Here we go again, the endless argument :D off that a bit....
I think these days, going to stock GTS-T to "stock GTR equivelent" is just not cost effective, *unless* you already pick up a reasonably modded GTS-T for only $2-3k more than a stocker. If you can buy a nice 32 or 33 GTS-T which has already the basics covered (suspension, intercooler, basic ecu mod, exhaust), you've got a great base to go further and you haven't spent the earth (nevermind time off the road and running back and forward). Just there you've saved maybe $5k as the stuff is already on the car and (hopefully!) all sorted and tuned nicely which somebody else has spent the $ on. Then all you really have to worry about is the turbo and getting it all refined. Even if the XXXX on the car is not what you decide you want, you can always sell those components and change them for what you're really after, and the "cross-grade" generally won't cost you too much.
The days of getting something from japan at a cheap cost are gone. Its all about the satisfaction of doing it "your" way, which can't be counted in $$$ i guess.
I agree with the tyres/suspension thing. I had a 180 that had 270rwkw on street tune or 327rwkw with good fuel. 270rwkw with 245's with a nice launch on grippy street would spin through 2nd and kick a bit sideways into 3rd. Put 195's on it (a heavy gts-t with 300rwkw would be not much better than this) and it was fun for a while but could easily get beaten by stockish cars till 4th. In other words 300rwkw is useless unless you have good suspension and tyres... and they are equally as expensive as engine mods.
I know there are differences like that but im not too technical so i wont go throwing around terms i dunno how to use internals are alos stronger too.
RB25 - 86 x 71.7mm
RB26 - 86 x 73.7mm
So neither engine is square.
Yeh, ok the metallurgy of RB26 parts is better then other RB engines, but how many of us are building race engines where differences can be realised? It woud seem that forged pistons are all that is required for those wanting bigger hp and additional headstart on reliability.
Maybe im over the hill, just turned 27 and the appeal of spending all my disposable income on my car has vanished, i think back to early uni lectures where they preached mech eng 101 "dont over engineer for the sake of it"
So what is a realistic shopping list for an RB25 owner chasing 300rwkw?
- Turbo, wastegate, manifold, water/oil lines - $5000
- ECU, Injectors and fuel pump installed and tuned - $3500
- Forged pistons and rings - $2000
- Clutch and flywheel - $2000
- Cams and cam gears - $1600
- General machining, balancing, bearings, gaskets, stud bolts etc - $2000
- Intercooler - $1500
- Full exhaust inc dumps - $1500
- BOVs (i know some dont think necessary but if im flowing enough cfm for 300rwkws id want two of the bastards doing there thing) - $500
Radiator(???) - $700
Then depending on the age/condition of engine things like reco head, new valve springs, new diff, better susp and tyres plus the other 30 otherthings that go into building a reliable 300rwkw engine?
blah, blah, blah, im talking too much :)
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
