Okay like most I have armorall lying around from gifts etc
Use it to detail the tyres mostly
My doorhandles and glovebox handle thingo are nearly white
Most people say armorall is the devils work etc.
My older revhed mates all say hit the handles repeatedly with the armorall
will eventually make em look the correct color
what is everyone using my handles look bad
rest of the interior is pretty resonable
other than the remnants on my dash of the black silicon previous owner used to attach the boost gauge
that will be the next mission I guess
Any suggestions????????????????
https://www.sau.com.au/forums/topic/305720-armorall/
I accidentally got a couple of drops of the stuff on my new leather gear boot. instantly took the color out of it. Now on the blue leather there is a couple of white spots that I'm stuck with. Not looking forward to the comments that passengers may come up with ;)
I wont be using it again. Slightly Damp cloth FTW
https://www.sau.com.au/forums/topic/305720-armorall/#findComment-5058623
Armor all is evil
It's basically a mix of solvent and sealer. The solvent gets in and attacks the plastic (vinyl / whatever) and the sealer seals it in to let it keep attacking.
You be the judge.
And it costs about 25c a bottle to make.
https://www.sau.com.au/forums/topic/305720-armorall/#findComment-5075144
I detail cars for a living and have found anything Maguiars is the shit! Not only do they work well but all their products smell good too, doesnt smell like chemicals. Amour all is absolute crap and will cause damage eventually.
If the plastic wont go back to its original colour try a bee's wax, that fixes most things! If that fails you may have to replace the parts effected.
Hope this helps.
https://www.sau.com.au/forums/topic/305720-armorall/#findComment-5075956
I use Mothers Naturally Black, you can buy from any auto shop.
Pour onto the plastic, let it sit on it for a couple of minutes, then massage it into the plastic. Then buff it after it has dried. Its a longer process than all the typical black restorations, but this is different as it isnt just some black liquid to hide the faded plastic.
https://www.sau.com.au/forums/topic/305720-armorall/#findComment-5076008
    • Yeah, you need to do it properly. You need to start out slow and gentle, ramping it up until they are good and hot, but not cooking, then roll off the other side (instead of letting them cool down quick).
    • I think yeah less hot fuel dumping into the top of the tank that wants to evaporate easily, fewer connections/hoses for permeation. Something like that. Also lower cost/easier production. Even my 2000 LS400/Celsior is a deadhead system. A single fuel hose to the fuel rails which have pulsation dampers attached and no return line.
    • I might do a few more high temp bed ins as described here.  I have a nice quiet 80kph road right near me.  How To Bed-In Your EBC Brakes For Street Or Track Use - EBC Brakes https://share.google/AjnOTILXoiqQnLu8p
    • I did a few 80-0 stomps. I then just rode the brakes while I applied throttle for a while to get them nice and hot. I live on a big hill and have been down it a few times also with stomps and brake riding.
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
