I am looking at 2.8 options myself at the moment, and a tuner responsible for the engines in some of the fastest time attack cars in Japan tells me they are using the Step Zero in the majority of their cars, all of which are producing at least 650PS and have yet to find the limits of the kit - Interesting feedback
It appears the Pistons and Rods included in the Step Zero are the same as those included in the Step 1, leaving the main difference as the crank
Let us know how you get on Blitz, interested.
So what is acutally different crank wise from the Step0 to the Step2? Is it just a lighter crank; is it still fully counterweighted?
interested as a future upgrade, hopefully will tally up nice with the my -9 turbos upgrade later this year
noob questions, will this KIT comes with all the bits that normally constitute a "RB26 mid life freshen up :) "
so that all you need is oil pump, coil pack,water pump,etc
does anyone know budget for install of such a kit
GOAL - only after super responsive Street GTR with loads of torque, Power around 280AWKW range, so not much
Here is the HKS spec sheet:
21004-AN009_012.pdf
There are a two different kits available, the full kit including crank, rods, pistons and rings/pins, and the piston-crank kit designed for use with factory rods, which only includes HKS counter weight crank and Pistons.
Both options available with either 86.5 or 87mm pistons
Will do, the kit has been ordered so will be sure to post up some pics and details once it arrives at the workshop :)
Looking forward to your results Nick....
Did you go 86.6 or 87mm pistons?
Did you get the kit with or without rods?
Very tempted at the moment as the kit without rods works out to half the price of the step 2 kit.
Jack,
I was informed by one of the HKS Pro Dealers in Japan that the Step Zero uses the same pistons and rods found in the Step 1 and 2.
I ordered the Full Kit with 86.5mm pistons which is going into a new N1 block :)
I can't find pricing for the step zero.
Is 400,000 yen for the full kit or just crank and pistons. I noticed the full step 2 kit through nengun is close to $9K.
Does the crank and piston kit still come with the rings and pins?
So your still going to use GTSS Nick?
Hey mate,
The 400,000 Yen is the 'Full Kit', so Crank, Rods, Pistons, Pins, Rings
The 'Piston-Crank' kit is significantly less but doesn't include rods.
Also worth noting for anyone questioning the quality of the kit, is all components are Japanese made.
I already have a new set of GT-SS's at home, so being that the Step Zero is designed for response, im going to chuck the GT-SS's on and see how far I can push them!
At that price it still works out to ber quite an expensive excercise by the time you pay freight, tax's etc.
I think the nitto 2.7 with the billet counter weighted crank might be a better proposition.
They claim it will rev to 12,000 rpm which is a shit load more than the hks zero setup.
  • Like 1
I have seen the Step Zero Full Kit as cheap as 357,000 yen (Approx ~$4,279.00 AUD) - Whats the best price you have found on the Nitto 2.7?
CJ-Motor lists them at over $9,000
Hi Octane lists them at over $7,500.00
Unique Autosports lists them at $8400.00
For a car being built for track purposes, the Step Zero is a fantastic kit, and the power, response and ultimate track performance that some tuners in Japan are achieving with this kit speaks volumes and is more than ample for my application. If I was building a drag car requiring the higher rev limit, it would be a different story.
Hey mate,
Should be good to see!
Any idea on the price of the crank / piston kit?
Rohin.
You're probably right Blitz, I was quoted around the 7 kay mark when i first enqired about the nitto kit.
The zero setup would be somewhere in the vicinity of 5500/6 kay landed so yeah, Its a fair bit cheaper but as you say, if you wanted to rev it the nitto would be the way to go.
how much labor $$ would we be roughly looking at onto of the $4.5k to get it all together? assuming you have a running rb26
Very interested in the labor cost
at the of the day, you need to budget and at least have ball park figure
how much labour $$ would we be roughly looking at ontop of the $4.5k to get it all together? assuming you have a running rb26
It all depends on who u get to do it, your basically rebuilding ur bottom end so wouldn't be cheap. If I was doing it I would get another short block and get it done, that way once it's ready pull the engine out take the head and sump off, put it all back in and retune. That way the car is off the road not as long, and plus you could sell your short and recoup some costs.
quoted for truth
if you have a running rb26 leave it! anyone who pulls a perfectly fine 26 out to build it is mad
building a bottom end is the same whether it was running fine or not (excluding putting a rod out the block of course)
call racepace and get a quote
My thoughts exactly and spot on the path I am going down.
I still need to sort out my sump and oil/water pump, plenum and a few other bits, but the block and internals will all be brand new, as will the head and associated hardware which is being setup, ported and assembled by a tuner in Japan then being sent over to me, so the target is to fully assemble the replacement engine and when its ready simply do an out with the old and in with the new swap
^ thought about this as well - reckon it's cheaper to get it put together there and sent out? I was wondering if you got a big workshop to do it, whether they could get parts cheaper than we could
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
