Hmm, neither my front or rear slimline plates (NSW) will go on the standard spots on the 'line easily.
I know that some ppl have bent / cut theirs, but I don't want to cut it (nice shiny new coloured plate) and bending it looks kinda like cop bait.
I was looking at using a pair of longer bolts and some washers, anyone else done same? (Although they won't be mounted flush)
Anyone got any suggestions / pics of what they've done?
https://www.sau.com.au/forums/topic/30579-it-wont-fit-number-plates-that-is/
I think outside of WA you need to use the state issued number plates, but then I'm just guessing as I haven't seen any non state issued plates in VIC or NSW.
my front plates are attached with a pair of spacers made from 2 oversized bolts from bunnings and a pair of long bolts (with allen key holes so you can't take it off with a screw driver) dunno why I went to the trouble as they're non slimline n non custom lol.
BD4s actually make a metal bracket that moves the front plate UP and AWAY from the bumper.
This has the effect of moving it UP, so it doesn't block the intercooler (GTR or front mounted GTS), and AWAY so you don't have to bend/cut the number plate.
I wish I had known they sold these before I bent my brande new plates :D
Nope, not at all... It would be piss easy.
But I don't know how to weld, I don't have the welder, and it's a thousand times easier to pay someone to do it instead of learning how to weld and buying a welder :D
Merli It's Christmas.....I'm sure funkeymonkey would pop up and do it for you ...if you asked him nicely :D
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
